boogielander
- Jun 29, 2022
all good. i have no bad experience with their CS.I have other reasons to shy away from BT. More personal with how a friend was treated.
I have over a pint of oil from my catch can with just under 35k miles and that means that oil has not gone into the intake nor around the valves or plugs. In my opinion cleaner is better.Easiest is none at all.
Only two reasons you'd need one. Direct injected and forced induction.
Other than that you are capturing water vapor with a small amount of oil entrained. Neither is that big a deal.
Is there a reason why it's different every time you empty it? I have the same issue with mine, just curious why this is happening?In 6.5k miles in my Ram I collected 7oz of oil. I put it in at 2200 miles when I did my first oil change (I didn't get my truck home until the 1900 mile mark as I drove it home from the dealership).
I always drain and weigh whatever I take out, and attempt to see what it is. Sometimes I get all oil, sometimes half water, sometimes a mix like a coffee with a bunch of creamer in it.
These are not GDI engines so a catch can is not required per say, but it does help prevent earlier required cleanings.
On GDI engines catch cans almost almost required because the oil and crud goes in and doesn't get sprayed to get cleaned. You can just look up catch cans for more info.
This is what I pulled out of my Silverado (I installed the can at 23.3k miles after the MAF sensor needed to be removed and cleaned to remove a check engine code)
Different driving conditions, different humidity levels. Different air temp.Is there a reason why it's different every time you empty it? I have the same issue with mine, just curious why this is happening?
It's not an "issue" like HSKR said.Is there a reason why it's different every time you empty it? I have the same issue with mine, just curious why this is happening?
Check out Speedlogix as well. Same catch can as BilletTechSomeone brought up a great point so now I'm seeking American made catch can. It's bad enough there's already parts in our trucks from china, I don't want to add any more.
Probably going with billet.
As do I, pretty easy install. Installed a few week ago, only put 1200 miles on my truck since September when i bought it, so I haven't had a chance to check it yet.This what I use. It seems to work good. i dump it about every 2 weeks.
J&L RAM 1500 3.0 Oil Separator; Black Anodized; Passenger Side 3067P-B (19-23 5.7L RAM 1500) - Free Shipping
Yup I use that one too. Took about 15 minutes to install it.This what I use. It seems to work good. i dump it about every 2 weeks.
Thanks for the info, that makes sense.It's not an "issue" like HSKR said.
I live in MA and I get all 4 seasons of weather so you can see when and how many miles.
During the cold winter months, I get more water, due to condensate just naturally happening, ice etc.
IndianaRam, what County are you in? I'm up North in LA Porte County.Thanks for the info, that makes sense.
Nice to see a local guy to me on here!IndianaRam, what County are you in? I'm up North in LA Porte County.
Hello neighbor.Nice to see a local guy to me on here!
What I have as well, transferred it from the Challenger I had. The Ram seems to accrue much more fluid than the Challenger did, though part of that may be that the truck spends more time idling (didn't drive the Challenger much in the Winter).this is what i use.![]()
Billet Technology Signature Series Catch Can For Dodge RAM 5.7L
Billet Technology is your premium source for your custom billet products for your Dodge Challenger, Dodge Charger, Dodge Magnum, Dodge Ram Chrysler 300 and Jeep Grand Cherokee SRT8. Manufactured in the USA at our facility in Lake Worth, Florida.www.custombilletstore.net
surprising how much crap it catches.
Every two weeks?This what I use. It seems to work good. i dump it about every 2 weeks.
