securityguy
Nor should you...that would be VERY dangerous if the truck even allows you to do so.No issues with rubbing except in entry/exit mode, but I never drive in that mode anyways.
It wouldn’t be dangerous so much as uncomfortable. You’re on the bump stops in the back!Nor should you...that would be VERY dangerous if the truck even allows you to do so.
Yeah I would like to hardwire it butt need to buy another one. I currently change it out of vehicles.You need to hardwire that radar detector! Super simple and will look a TON better
Yeah, but shouldn't need to with air suspension as it will adjust to whatever load is added by lowering the front end accordingly.All of the 2019 - 2021 have a rake where the front is lower than the rear. It balances the load in the bed.
Well I have to wait for mine to come in!Need more Limited Night Edition owners to post pics!
They are all the same if left stock. Rear is higher than the front. Thanks for believing meYeah, but shouldn't need to with air suspension as it will adjust to whatever load is added by lowering the front end accordingly.
I knew they all were air rides but until I started doing some research around here I had no idea it was so much more in depth.PITA to level or lift air suspension equipped trucks which all limiteds have.
There are kits available for the air suspension trucksI knew they all were air rides but until I started doing some research around here I had no idea it was so much more in depth.
That was my first color choice but i ended up going with white cause i wasnt willing to wait. Wrapping is always an option.Just saw a red (the dark metallic red) limited night edition at the dealership. Man, does it look good, dang it! If it was there when I bought mine, I probably would have gone for it. Anyone have a red one?
Nice ram boxes!Thread for a compiled album of the Limited Night Edition as it looks on different colors.
Here's mine (Ivory Tri-Coat Metallic)View attachment 81055View attachment 81056
i'm diggin' the gear knob! is it a cover? where did you get it?
www.ajtdesign-llc.com
Thanks for the link!![]()
Products | ajt-design
