Just left my dealership, the guy said he doesn’t know but looked up the build sheet they can see and nothing on there was about HD shocks or springs, he just said some trucks are built different, I was explaining to him that ours are built with it. But then just asked him for rams information and emailed ram about it
Thank you all for this incredible thread. I've had the suspicion that something was off about the ride height of my truck. My neighbor has a Rebel (which has the same ride height as a regular Big Horn with the Off-Road Package) and my truck sits a tad lower. The rear I don't mind so much, but the front looks so low when compared to the Rebel and even trucks with the off-road package. Is there Any way to for someone to list out the part numbers of the springs and shocks that are on an off-road package truck so we can compare them? My build specs say "raised ride height" and "Front Extra HD Shock Absorbers" and "Rear Extra HD Shock Absorbers". Having the part numbers would make it an easy argument with Ram Care and the dealer for them to make the necessary corrections.
Thank you all in advance.
I do have raised wheel height on my sheet, also the extra HD shocks. I have the "off road group" springs and shocks
build date is 7-20 MDH is 072412 purchased 9-27View attachment 68024View attachment 68025
I think he's confused. Which is where my post came from. Hopefully we all get it taken care of so we can be happier with our trucks.
Do you have an open case with customer care? I would relay the message to them. This truck was not sold to us as advertised and the parts need to be replacedWell, I'm glad you're having a positive experience. Gentleman I talked to in service seemed to have a dismissive attitude the entire time I was explaining my situation. He then took me to the parts department so that we could look up my VIN# and see what parts should be on there. The computer came back with 0237AB - which is what is installed. When pressed on why my truck would sit an inch lower than the various trucks that have been posted here or facebook I was met with "I don't know" and "We haven't into this so we don't know how to proceed."
At this point I'm not sure how to proceed either.
So the parts department told you your part number? I’ll double check with them later I only spoke to service advisorWell, I'm glad you're having a positive experience. Gentleman I talked to in service seemed to have a dismissive attitude the entire time I was explaining my situation. He then took me to the parts department so that we could look up my VIN# and see what parts should be on there. The computer came back with 0237AB - which is what is installed. When pressed on why my truck would sit an inch lower than the various trucks that have been posted here or facebook I was met with "I don't know" and "We haven't into this so we don't know how to proceed."
When I search the springs listed a few posts ago it says they are discontinued and replaced.
BUILT TO SERVE EDITION | |
CODE | DESCRIPTION |
ASG | Built-to-Serve Edition |
SFDP | Front Extra HD Shock Absorbers |
SGDP | Rear Extra HD Shock Absorbers |
ZADP | Spring Front Left |
ZPSP | Spring Front Right |
ZBSP | Spring Left Rear |
ZNDP | Spring Right Front |
XZNP | Raised Ride Height |
Off Road Package Truck | |
MPDP | Off-Road Decals |
ZBCP | Spring - Left Front |
ZPCP | Spring - Right Front |
ZCWP | Spring - Left Rear |
ZRWP | Spring - Right Rear |
