If you're in a very cold environment, I would seriously recommend you not get the air ride. It's a fact, it will fail after 2 or 3 winters. There have been no substantial updates to the air ride for years and the fact that they still use Continental parts is a red flag. Air ride is great for access and wow factor... but it's not for cold climates.What is the difference between suspension off road and air suspension and which is better?
IIRC:
- In general, don't almost all air suspensions (non-big-rig kind anyway) have issues in the cold? I think I recall this from another rebel board, someone brought it up
- I think the problem start around 0 degrees Celsius.
More time/wear and tear, more cold = more likelihood of an issue.
I want to keep the next truck forever if I can, I'm opting for springs for that reason.
That and payload doorsticker availability.
That and lift-ability.
But I will say that air suspension was absolutely awesome at leveling loads and being comfortable.
I'm glad you didn't endure the nightmare that thousands of us have experienced with air ride in extended extreme cold. It's not for me to convince anyone, I have no vested interest in the promotion of failed air ride, I just speak from experience and fact. I've battled for a recall and have seen many Canadian customers buckle under the heavy foot of FCA. We don't have lemon laws here to protect us. We have Canvap and private lawsuits, but who has the ability to fight a major manufacturer that denies a customer compensation... I don't.I had mine 4 years without issues, and they must of changed something because the ride is quite a bit more stiffer than my 2015. I can't prove that they changed anything for air (appart from different part numbers), but it's definitely faster at up/down and a bit stiffer.
If you see -30° once a year, your air ride will probably last more than a few years. If your winter is 5 months long, I wish you all the best. Best to order that coil conversion kit now... it's only a matter of time.
I wish I still had the picture I took two years ago, of 26 Rams at one local dealer, all in different odd angles with failed air ride systems waiting for the same answer. Sorry, we can only thaw and recharge the system.
But I digress, we're all big boys and can judge for ourselves. I just hate when the "I told ya so's" start to come out.
I heard the closed loop nitrogen system is redesigned and that it is more powerful so it can lift the truck faster. The pump sounds louder than my Jeep GC which shared the same system as the previous Ram.
Probably just the Jeep being quieter due to mounting differences. My Limited sounds louder...but the bed resonates the sound of the pump. Since you owned a prior model Ram, I defer to your expertise,It is definitely quicker, although I didn't notice much of sound difference.
Sorry, didn't want to start a pissing contest over who's winter is colder. And I didn't intend to insult you, or your inherent luck with your air ride equiped Ram. I hope you stay warm and have a great winter this season in your new Rebel, they are a hell-of-a-truck!I live in western Quebec (Gatineau area), and we have quite a few more days colder than -30 Celcius. I have heard the numerous issues some owners experienced, and I can only provide my experiences with it. The real issue for me was the Ecodiesel (a total piece of $h%!), they replaced the first engine at 60,099 KM, and that engine had a catastrophic failure less than 2,000 KM later. Luckily for me this happened when it was under warranty, but was about a month without a truck for the numerous issues I had with the Ecodiesel system (EGR, DEF, and Catastrophic failures).
Because of my experiences with the Air ride, I purchased the option again. As such based on how this truck's suspension feels and works (way faster than before and stiffer ride), I can only suspect that some improvements have been made.
Attached are the "averages" for Chelsea for temps. https://www.theweathernetwork.com/ca/forecasts/statistics/quebec/cantley
View attachment 8103 View attachment 8105
