ORG and Protection Package are both on hold right now. Probably a supplier shortage. I'd order the Air Suspension and you can bolt on the Protection Package later. You won't get the 1" lift but you will get all the same ride heights for off toad use. The ORG does include a slightly stiffer suspension. Don't forget to order the Anti-slip differential. Not sure you can get the eLocker without the ORG. If so, then choose one or the other. For a daily driver the Anti-Slip might be best.
Thank you for your suggestions. I really want the ORG for that 1" lift. ORG includes the Protection Package, Anti-slip differential, and eLocker. You can select eLocker by itself without ORG.
I guess I will have to wait until they put the ORG back into production. Any Idea when that might happen? How did you find out that information as I have been trying to look it up.
This is the build I have sent to several Dealers in my area in the panhandle of Florida. A couple of them have already mentioned not able to get the ORG but they have no clue as to why. One of them said it was because I had wanted air suspension too, another said I couldn't get etorque engine with ORG. Crazy! lol
2019 1500 Ram Longhorn Crew Cab 4x4, Maximum Steel Met. Clear Coat, Mountain Brown/Lt. Mountain Brown, Premium Leather w/Filigree, 5.7L HEMI eTorque, Advanced Safety Group, Off-Road Group, Level 1 Equipment Group, Tri-Fold Tonneau Cover, 3.92 Rear Axle Ratio, Dual Pane Panoramic Sunroof, 33-Gallon Fuel Tank, 4-Corner Air Suspension, Trailer Brake Control, Body Color Bumper Group.
