bigdodge
Happy Ram Owner
- Aug 25, 2021
- Location
- southwest. where majority rules
then change the thread title!!!
Maybe read the post completely. Nothing like assuming things from a headline or title. I admit, I could have worded my post differently.then change the thread title!!!
you are missing the pointMaybe read the post completely. Nothing like assuming things from a headline or title. I admit, I could have worded my post differently.
Must be a slow Thursday, huh.
Ok it's fine that you made an a s s of yourself. If you took the time and read the post you would have understood. Why didn't you throw out a "prove it" post on the topic?you are missing the point
the title of the thread holds a lot of weight with readers
that is just the way it is!!
there is no making an a s s of you and me it is what it is!
Do you know you have an open recall?wawawawawawa
I don't believe you. I need proof."There are no outstanding campaigns for the above listed VIN."
I texted Angelo at Mark Dodge and he replied today that he had just finished placing an order for a Limited, and it would only allow him to select the Etorque version of the Hemi. I'm not too concerned, I was a little worried about the reliability of the system, but after searching around, it appears to be a pretty trouble free system. It just sucks that they are charging for what should be a standard engine now, adding another 2500 to the price.Can't get hemi without etorque on Laramie currently. You can get it in a limited
But does it?It does other things than the auto restart…
From what I read there is no torque boost, I have read and watched several articles state it's only the first half wheel turn after the start-stop (which explains why the truck goes flying forward when I take my foot off the brake when it stops without touching the gas) and the electric motor DOES NOT add to the total torque of the engine.Yes. You still get the off the line tq boost, and regen (engine braking) from it. Even when you “turn it off”
Also the regen doesn't mean anything if you aren't using the battery, in fact that means less mpg as you are slowing the vehicle to charge the battery (if you don't use auto start-stop that is).
Please quote your source of who is claiming the etorque kicks in to provide power with the auto start-stop disabled as every reputable source was very tight lipped and was clear it didn't provide power while actually driving only when stopped when the gas engine was off.
I did use google and researched before I bought my truck.Mine doesn’t fly forward, that sounds like an update issue.
Regen works as an engine brake reducing the amount of actual brake wear, have zero affect on mpg.
And there are tons of articles out there about it. The system is 3 years old, use google.
