New tires and wheels
Jmort1754
So after all the reviews on 18 inch rims it has the 20 inch rims.
I might just put some new tires on it for this year.
What size can I get away with a bilstein 5100 level and oem rims?
Was looking at 285/60
Exo grappler or really like the looks of the Toyo at3
I'm running 275/65/20 Kenda Klever M/T
This was with Bilstien 5100 set to circlip 4 on my BTS with factory ORP. I have 1" spacers in rear, and 3/4" up front, but wouldn't need them with these tires for clearance. I am just running then to push the tires out flush with fender flares for cosmetic reasons
Jay R
I hate to ask, but can you get more pics? I have eibach front adjustable shocks being delivered soon. I need to figure out what tire size I need. I also have BTS edition
Kroger
What tire size did you end up with? I have a night larmine with ORP, same rims. My factory tires are about ready for replacement and looking to add the 5100’s up front and debating between the 275/60/20 or 275/65/20’s. Any rubbing your with your new setup?
Thank you!
Thank you!
Definitely go 275/65/20 to fill out wheel wells a little more
Lpsouth1978
I don't know how much lift the 5100's provide, but I have 295/65/20s on my Laramie with a 3" front level (aftermarket wheels though). 20220108_094118.jpg
Thank you! On your husky mud flaps, did you get any rubbing with that size?
Zero rub with 2" front level. I also have 3/4" Bora wheel spacers on the front, but that wasn't to prevent rubbing. It was for aesthetics and pushing the sidewall even with fender flare.
Jay R
Thank you!
My installer put the eibachs on the 2nd clip instead of the 3rd. I ended up putting 295-55-20 on factory wheels. Nitto recon grappler
Jay R
Thank you!
295/55/20 recon grapplers
WyoRam21
295 60 Mickey Thompson Baja Boss A/T on stock rims and set the Bilstein's to 5. The rear is still 3/4 inch higher than the front.
