New tires and wheels
Jmort1754
So after all the reviews on 18 inch rims it has the 20 inch rims.
I might just put some new tires on it for this year.
What size can I get away with a bilstein 5100 level and oem rims?
Was looking at 285/60
Exo grappler or really like the looks of the Toyo at3
This was with Bilstien 5100 set to circlip 4 on my BTS with factory ORP. I have 1" spacers in rear, and 3/4" up front, but wouldn't need them with these tires for clearance. I am just running then to push the tires out flush with fender flares for cosmetic reasons
I hate to ask, but can you get more pics? I have eibach front adjustable shocks being delivered soon. I need to figure out what tire size I need. I also have BTS edition
What tire size did you end up with? I have a night larmine with ORP, same rims. My factory tires are about ready for replacement and looking to add the 5100’s up front and debating between the 275/60/20 or 275/65/20’s. Any rubbing your with your new setup?
Thank you!
Thank you!
Definitely go 275/65/20 to fill out wheel wells a little more
I don't know how much lift the 5100's provide, but I have 295/65/20s on my Laramie with a 3" front level (aftermarket wheels though).20220108_094118.jpg
Thank you! On your husky mud flaps, did you get any rubbing with that size?
Zero rub with 2" front level. I also have 3/4" Bora wheel spacers on the front, but that wasn't to prevent rubbing. It was for aesthetics and pushing the sidewall even with fender flare.
Thank you!
My installer put the eibachs on the 2nd clip instead of the 3rd. I ended up putting 295-55-20 on factory wheels. Nitto recon grappler
Thank you!
295/55/20 recon grapplers
295 60 Mickey Thompson Baja Boss A/T on stock rims and set the Bilstein's to 5. The rear is still 3/4 inch higher than the front.
