Right, some discreet switches still remain but not many! Just find it hard to believe a wire would be open somewhere but that's where I'm headed....I was a chrysler mechanic long long ago, so things may be different. Now so many things are actually controlled by the BCM. Back in the day, there was a relay. It could have 1 fuse for switch power, and another, high amperage one for the actual grid power. Maybe you will get lucky, and a more current mechanic will chime in.
Look very very carefully at all the lines. If anything scratched the glass and removed the conductive coating it breaks the circuit. Usually you only loose a line or two but a break in the right place can knock the whole thing out.Bought a 2019 Ram 1500 quad cab and love it. Only thing is rear defrost does not work. No power at connector on rear glass and fuse is OK. Doesn't seem like there's a relay either. Any advice?
Good advice thanks. However, not even getting 14v to the window connector. Seems like an open wire somewhere between the fuse and the connector.Look very very carefully at all the lines. If anything scratched the glass and removed the conductive coating it breaks the circuit. Usually you only loose a line or two but a break in the right place can knock the whole thing out.
This is excellent advice guys! Not sure why I couldn't find this circuit via surfing?Ratchet's post pretty much confirms my earlier post. It looks like fuse 11 is for control circuit. ( feeds low power of relay, making it switch on, and feeding the light on the switch) Fuses 46 and 46 would be the high draw side of the relays. ( actually powering defroster ) Check those 2 fuses. If they are good, check the relay. If it is working, you have a break in the wiring.
Haven't worked on them in years, so I can't help, but when I just referred back to Rachets post, to see if there was a clue, I noticed fuse number 47 under the hood is also in that circuit. Check it too.Any chance you know the relay number? View attachment 153121
I found the fuses! Will check them, thanks again!Here is the defogger circuit. This should help ya out a lil bit.
Anytime.I found the fuses! Will check them, thanks again!
I'm having the same issue with my 2016 Ram 2500, were you able to resolve your issue?I found the fuses! Will check them, thanks again!
No, I kinda stopped trying to fix it when weather warmed up.I'm having the same issue with my 2016 Ram 2500, were you able to resolve your issue?
Thanks,
