New member with rear defrost problem
Hexman62
Bought a 2019 Ram 1500 quad cab and love it. Only thing is rear defrost does not work. No power at connector on rear glass and fuse is OK. Doesn't seem like there's a relay either. Any advice?
Welcome... does the switch light up when you press it? could be disconnected from the back somehow?
Yes, the switch does light up and the connection to the window is not connected. I removed so I could check voltage. There is power at the fuse but not at the window connection
There seems to be an open break somewhere between the fuse and the rear window. You probably will have to trace the wiring all along the way. How is the window grid grounded to make a complete circuit? You should check that as well.
I was a chrysler mechanic long long ago, so things may be different. Now so many things are actually controlled by the BCM. Back in the day, there was a relay. It could have 1 fuse for switch power, and another, high amperage one for the actual grid power. Maybe you will get lucky, and a more current mechanic will chime in.
Right, some discreet switches still remain but not many! Just find it hard to believe a wire would be open somewhere but that's where I'm headed....
Look very very carefully at all the lines. If anything scratched the glass and removed the conductive coating it breaks the circuit. Usually you only loose a line or two but a break in the right place can knock the whole thing out.
Good advice thanks. However, not even getting 14v to the window connector. Seems like an open wire somewhere between the fuse and the connector.
Here is the defogger circuit. This should help ya out a lil bit. ;)
Ratchet's post pretty much confirms my earlier post. It looks like fuse 11 is for control circuit. ( feeds low power of relay, making it switch on, and feeding the light on the switch) Fuses 46 and 46 would be the high draw side of the relays. ( actually powering defroster ) Check those 2 fuses. If they are good, check the relay. If it is working, you have a break in the wiring.
This is excellent advice guys! Not sure why I couldn't find this circuit via surfing?
Kind of the same problem here, since the truck was new many of the ‘lines’ in the window didn’t defrost and now its down to only 1 or 2 that do. Finally remembered to ask the service department about in on last service and they have ordered a whole new window under warranty.
I found that the passenger side contact "button" came off the solder pad of the rear defroster when I pushed the rear seatback forward to inspect it. After seeing mixed reviews from owners using Permatex & Loctite conductive adhesive solutions, I have decided to go the solder route instead. The adhesive methods all seem to require at least several hours of cure time in a 50 to 80 degree ambient (longer if colder); that's simply not practical in the 3rd week of December here in New England.
A rosin core solder and a 100W to 200W soldering iron (or a butane fueled type) should make fairly quick work of this with zero curing time required. I'll use a popsicle stick (or similar item) to hold the hot contact button in position for 10 - 15 seconds after the heat source is removed. I'll be able to reconnect and use the defroster immediately afterwards. I'll use a heat gun (or blow dryer) to heat up the glass a bit from the outside to help keep the cold glass from acting like a heat sink while I'm trying to melt the solder inside. A cold-solder joint will likely fail sooner rather than later.
If you decide to go this route, make sure you do not use plumber's soldering paste or flux as they contain acid and it will eat through electrical connections and cause them to fail over time. I've read online that in a pinch, white petroleum jelly (Vaseline), lemon juice or even WD-40 are acceptable flux substitutes (I haven't tried them - so I can't say how well they work) and would be better than plumber's types. Rosin is a popular flux used in soldering operations in the electronics industry and when it is incorporated in the core of solder - it is a no-mess way to apply it.
