You should be good now.  2020 2500 Laramie 6.4 hemi, bigger gas tank also. I had the same thing happen last winter.  Could not fill my gas tank and went to 3 different gas stations and was very slow at filling.  Come to fine out it was with the vapor canister but the check valve itself.  Whenever you shut the truck off the valve should always be open so when you fill your gas tank there is a place for the vapors to go thru which is the vapor canister.  So, for the tech to diagnose the problem he took truck to gas station and began to fill tank and could not.  So, to bypass the problem he climbed under truck to gas tank and removed a hose to let air, vapors, out of tank and bypassed the check valve.  Ordered new check valve and has been good ever since.  So in the end it was the check valve and not the canister tank.  Inside of the canister tank is some type of charcoal filter system that the EPA dreamed up years ago......This was just my results of a very very slow filling gas tank with my truck......
