19RamLimited
- Jul 25, 2018
Ha Ha.. yeah.. and thanks to you I cant edit itbest autocorrect post I’ve seen in a while... I’m pretty sure you mean issues....
I just wanted to help.... and point out that you are trolling and calling Rustyhames, as well as all of us other Ram owners, sissies.....Ha Ha.. yeah.. and thanks to you I cant edit it![]()
I did this morning and I fixed the volume problem. But now the screen goes blank occasionally and I have to stop and put it in reverse and the backup camera will engage and I can go back to drive and it works fine.Have you tried disconnecting the positive battery terminal cable for like 10-15 mins?
I have the 8.4 and had somewhat of a similar issue. My volume would go right to max volume with either the radio or the navi on. This happened during my entire trip SC back to NJ so I could not use the radio or the navi. The dealer could not replicate it because, of course, the truck went back to normal before I could get it in to the dealer. It has not happened again but just yesterday, only the back speakers worked when I used the Navi. I shut the truck off and walked away from it. When I started it again it was back to normal. I am going to videotape it then next time it happens.
As for the poster thinking you should expect problems I buy 2 new cars every year. I almost always get the latest technology. That's how I ended up with the new Ram. I have never a tenth of the problems I have had with this thing.
It's an awesome truck and they will work out the software problems over time but the air leak in the sunroof was bad.
Thanks for all the replies
I’m hoping for a update, sooner than later. It has a mind of its own for sure.
To be fair, the folks who monitor the @RamCares account never say they intend on a two way conversation, I have only ever seen them say they will add your forum comments to any ongoing file/case for you truck. If that is actually happening, who knows.I have sent a PM and never received a response.
If @RamCares asks for you to send them a Private Message it is only fair to expect them to check their Inbox daily and once received, they should acknowledge that in a reciprocal PM. It only takes a minute and gives the customer piece of mind that their concerns are being met. I completely understand @whododat frustrationTo be fair, the folks who monitor the @RamCares account never say they intend on a two way conversation, I have only ever seen them say they will add your forum comments to any ongoing file/case for you truck. If that is actually happening, who knows.
