My 2019 Limited became a zombie overnight :-D
cdn.tbird
So interesting thing seems to have happened to may baby. Went out yesterday morning and my key fob wasn't working. Grabbed my wife's fob and same thing. All the doors were unlocked which isn't normal. When I opened the door to get in, the sidestep extended like normal so I knew it wasn't a dead battery. Dash displayed press brake to start but when I did nothing happened. Didn't even get a message that the key fob was missing.
First thing I did was swap in a fresh battery for my remote, same thing. Grabbed my battery tester and confirmed what I already knew, my battery is in good health and was near full capacity.
Tried pressing the start button with the key fob, nothing. Tried disconnecting the battery cables and keeping them together to reset the computer, nothing. As luck would have it, I had picked up a new H7/94R battery for my wife's SUV so I even tried swapping out the battery, which I knew wouldn't do anything but hey it was worth a shot even if it had less of a chance than a Hail Mary. :rolleyes:
Roadside Assistance just picked it up and its on its way back to the dealership, thank goodness for an extended warranty.
Has anyone experienced this?
Ros
5thGenRams Supporter
Similar to what happened to my truck - only since it was locked every time the door was opened the alarm went off. Issue was a fried RF hub. Since it was fried it could not communicate with the keys.
cdn.tbird
You RF Hub is probably fried. Is your rear window leaking?
Thanks for the info. Knock on wood, I haven't seen any signs of leaking. I remember reading about the leak issue when I first got it and was super paranoid about it and would check constantly.
Fingers crossed, I just got off the phone with the dealership and if they can, they'll try to get it in today but most likely it will be Monday before I have news.
Eighty
Moderator / Dream Killer
You running a Tazer on this truck?
Ros
The tech checked for water on mine and there wasn't any sign of leaks either. Apparently mine just went bad. Hope they figure out it quickly for you, it took my dealer over a week to diagnose the issue.
kapinallinen2
Southern Maryland.
You have a 2019 with an original rear window frame that is not leaking!
Not saying that is not possible, but yeah, my bet is also on the RF hub.
SpeedyV
Ram Connoisseur
Fort Worth, Texas
Sometimes the battery has just enough juice left to deploy a step. Hopefully you started with potting it on a charger to eliminate that concern!
cdn.tbird
With it being a 5yr old battery, one of the first things I did was put a tester on it to ensure it wasn't the problem. Battery health was reporting 95% with an 89% charge. Plus I swapped it out with a brand new battery and got the same results.
cdn.tbird
Sorry for the delay in responding, it's just been an absolutely insane week for me at work. Picked up my baby last Friday, it took then a couple of days to get a new RF Hub. Spoke to the tech that did the work, and thankfully there was no sign of water infiltration through either the rear window or CHMSL.
mikeru82
The Palouse
Thanks for the follow-up. Good to hear your window isn't leaking. Hopefully it stays that way and your truck remains dry inside!
Ros
Good news! I recommend keeping an eye out for water intrusion. I was told the same thing and a few months later I had to have my rear window replaced and am currently waiting for full carpet/padding that's on back order. :(
