StuartV
Thats big part of my point. I'm talking about the 2020.not the older ones.
Are you saying that you think the new ones get worse fuel economy than the previous gen?
2020 Longhorn Ecodiesel Shortbed.
at 60 I get 37, at 65 it drops to 33, 70 27-29. 75 its around 25 and 80+ its 22ish.
I'm in FL on flat ground so it's not terrain much.
at 45 mph, I've had as high as a sustained 56 mpg.
I can also say that after throwing out the 80lb AGM battery and installing a 18lb Lithium my mpg went up enough to see the bump in torque pro logs.
Out of curiosity, which lithium battery did you install?
i seriously get like 13 mpg combined city/highway, idk how all you guys are getting these numbers. i dont baby my truck like a grandpa but i also dont drive like a d!ck, i go along with the flow of everyone else. any pointers are appreciated i know my 3.92's, level, and 35's dont help, but i really dont feel my mpg's are different than when my rebel was stock.Not bad at all for a rebel. Those big tires and lift certainly don't help the MPG
I find the difference between the Ram's calculations and hand to be .30 with the Ram reporting higher. This is with 17,998 miles. There can be larger differences both + and -. My experience is that it all depends on the consistency of speed prior to fill ups. If all the driving is highway the differences will be minimal. However if you change your mph the discrepancy will be greater. The mpg calculator appears to depend more on final mpg prior to fill up.His IS a diesel...
And, if those numbers were coming from the trucks lie-o-meter, then there is no way to know how accurate they are. I have logged every fill-up since I bought my truck (20K miles ago) in Fuelly and the lie-o-meter is almost always optimistic - by as much as almost 2 MPG. But, every now and then, it will be spot on - just to let me know it is totally not consistent.
What rear end do you have?Averaging 27mpg so far in my EcoDiesel with mostly highway driving.
