I searched for some details into the bed light kits from mopar on the site here and didn't see much related to my issues I ran into during/after install, so I thought I would post my findings to help anyone avoid the problems I ran into.
Yes, it is a long how to when you look at instructions but to me it wasn't that bad, probably had a couple hours wrapped up in it total install. Steps that could be skipped include removing wheels and dash piece under steering wheel, there's plenty of room to work around both. Honestly the part that took longest was removing and installing wheel liners simply because of so many screws by hand and then working them out/in of the wheel wells. Lights and then running the harness was straight forward and easy.
Issues began at plugging the wires in at the BCM (And just for context I am an auto tech). The instructions I come to find out were wrong, which I questioned as I was installing sprawled out, upside down, in the dark, the first evening we got the truck lol do not follow the picture for C7 connector as it is wrong. I did a double take when I had the connector out because it had the 12 and 24 molded on it for the pin numbers, but against better judgement I thought, no I'll do what it shows. Well come dealer time it wouldn't work and they spent 3 hours figuring out nothing, so I had another appointment this morning and first thing i asked for was pin location diagram for those connectors and sure enough my skepticism was confirmed from my install. So I went out and switched the wires to where they should be. In the daylight today it was much easier to see everything. The pin numbers are also molded on both sides of the connector top and bottom pins (would have been lovely to see the first time around) and at least on a Laramie trim truck there are same color wires in those locations you pull out and tape back.
Anyway, in hope of saving someone else from all this trouble and two dealer trips I wanted to put this out here. I will attach pics of the instruction diagram and the connectors in truck.
