Mold Under Rear Seats
rontee
@RamCares I noticed mold on a roll of tape under my rear seats. Will Ram cover the removal of the mold or replacement of the carpet underneath my rear seats? I have an appointment on Wednesday, July 10, 2024 to address the water leaks from the rear window and 3rd brake light.
Ramcares doesn't make that decision and can't answer that question. They are here to facilitate between you and your dealership. You'll hear soon enough after your appointment. I'd be more concerned about why there's mold growing back there. It's likely you have a water leak in one of the common areas for leaks...rear window, 3rd brake light, shark fin antenna, cab vents, or sunroof drains.
It's also helpful to provide information about the vehicle you're asking questions about. It's even more helpful, and strongly advised, if you add that information to your signature, as many of us here have done.
Finally, the content of this thread has to do with your truck's interior and has nothing to do with the powertrain. It's best to create a thread in the correct forum. In this case the Interior forum...
My opinion: once you stop the water intrusion, the mold will die. A simple carpet cleaning/vacuum (with a cleaning spray?) should remove the remnants.
If you, or anyone who may be in your truck, has mold sensitivity, then a bit more would be need to be done.
I'd go to the dealer with your concerns. Good or bad, let us know what the dealer ends up doing.
It could also be cab baffler behind rear seat and not window or light. Had to replace mine and that stopped the water leak.
Are you still under the 3/36 warranty? Then you'll likely get all that replaced. I did due to the sunroof drain issues. Interior completely removed and new carpet installed under warranty.
Are you out of that? Then nope.
Hi there,
Please feel free to private message us with any updates from your appointment. We look forward hearing from you.
Gia
Ram Cares
Hi there,
Gia
Ram Cares
Thanks for the reply Gia but I think you quoted the wrong post there.
I had a similar situation and felt overwhelmed until I used professional mold remediation and removal services, which handled everything from the free assessment to full cleanup and documentation. They even checked my HVAC and helped me figure out what materials actually needed replacing instead of guessing. It made the whole mess way less stressful.
