cevans6318
gonna leak test just the corner of the glass later and see if it starts to come in. if not, then directly on the third brake light. I initially removed it and everything looked fine. Really weird for it to leak and only cause the drip at that corner. truck has been outside all day and it has been pouring non stop since this morning. curious to what I will walk out too.Either side like that could also be third brake light seal, the cracked frame tends to have drips closer to either side of the slider. Good luck, I've had both leaks, sealed my shark fin also just in case to eliminate the third possiblity
