Neurobit
RAM Sorcerer
Fair enough. Maybe it is different than the 2018s and earlier. Cheers.In previous years yes. Do you work for Chrysler and can provide some documents to show that the regional rep was wrong?
My 2012 ram 1500 did this and got horrible mpg so on a cross country trip I took along a half filled gas tank for backup drew the tank down to about 5 gallons and put 4 bottles of seafoam in it. Now with no head wind or verticle climbs, when it is on under 70mph it runs solid. I cruised from NM to NC with it and averaged 20mpg in speed ranges between 65 and 75 after treatment. Before that I was getting 13 to 19 highway depending on the conditions. Running a windows driven OBD I read there were some cylinder misfires. I'm not smart enough to know what this means and if it was related. But you might want to check for that.I don't know if this has been discussed before but, It Appears the MDS in my RAM doesn't engage like it should. while traveling at a constant speed it rarely engages, but when I take my foot off the gas or disengage CC the ECO tight comes on. I had a 2014 Charger R/T and it always kicked in when it was supposed to. I have the 3.92 rear end, don't know if that makes a difference.
ECO light is turned off by default. You need to enable it from within Uconnect in settings.So Im new to trucks in general. I keep seeing this MDS and ECO in the forums but haven't seen any light come on. I watched a few videos on how to enable the light via the settings but mine doesn't show that option. Do all Rams come with MDS?
I have a 2019 5th gen Ram bighorn Hemi with tow package.
LOL - You beat me to it......but they don't call it MDS or Eco in the UConnect settings. I seem to recall it's something like 'fuel saver' or something like that. Has been discussed in detail a number of times in the forums.
Here you go with UConnect screen shots: https://5thgenrams.com/community/threads/eco-mode-fuel-saving-mode-not-working.1558/page-3
"Fuel Saver Display"
You've been misinformed. When the ECO lamp is illuminated it does indicate that you are in the 4 cylinder mode.I saw on one of these replies that someone didn't notice the MDS kick in until they had around 400 miles. I get my Eco light on a good amount but I have never noticed a difference in sound or feel to indicate that MDS has kicked in and until I just looked back over my window sticker a few minutes ago, didn't even know I had MDS on the engine. I have had the truck since the 7th of this month so around 3 weeks now and only have around 370 miles on it. Most driving is back country roads doing 45-60 MPH here in NC and only had it on the highway once. You would think Mopar would put in a light or something to tell you that you were only running on 4 cylinders. I know Chevy does that in their truck with a light that comes on that says V-4 or something like that. So does it not kick on until the engine has "broken in" with a specific number of miles driven?
I know from other reading that the Eco light is just a light saying "hey you are driving efficiently" and doesn't nesecarilly correlate with MDS being active.
No. There is not light for MDS.
Eco light will turn on (if enabled in UConnect first) if you are driving efficiently, regardless of MDS being active or not.
