Not abnormal for the truck to be little lower on driver side, go to the dealer lot and measure several trucks and you will probably have the same result. Measurements may vary depending on how much gas is in the tank.
As far as the door, NOT normal at all, def have the dealer check that out.
Some light reading.
I have seen a couple discussions on other sites regarding my truck being about 3/4 inch to 7/8" lower on the driver side rear. My truck is a 2020 ram 3500 4x4 long bed HO Diesel. I have about 4000 miles on it now hoping that it would settle down but it has not. Some people blame it on the fuel...
5thgenrams.com
Hi, noticed when washing my truck that it is leaning on one side. Air ride set to normal, on even pavement. Has anyone heard of this sort of problem ?
5thgenrams.com
Hi, All so I have a 2019 Ram Rebel “none air ride” My truck is off by 1/2 on the rear. When I measure from the top of the tire to the finder I’m at 7.5” on the drivers side and 8.25 on the passenger side. When I measured from the ground to the top of the shock mount both sides are at 31”. The...
5thgenrams.com
