theblet
- Feb 8, 2021
As far as I know yesIs this issue only on the V-8s?
There doesn't need to be deaths for them to issue a recall.They won’t consider it a recall until a certain amount of people die from it. And the courts would have to prove the cause of death is directly from the manifold leak.
I think they should at least extend the warranty like they did with the AAD. That probably won’t happen either.
Right, but I doubt they would issue a recall unless that happenedThere doesn't need to be deaths for them to issue a recall.
I understand that. I was asking why it's "extra time" to replace broken bolts, when it's doesn't take extra time.
Extracting a broken bolt vs not.... common sense explains why it takes longer.How would replacing broken bolts be more time than replacing the manifolds?
No IF a broken bolt needs to be extracted, there will be an extra charge. Doesn't matter if uncle wally's garage or dealership is doing it.Because stealerships.
There doesn't have to BE a death, but there has to be a possibility. Recalls are only issued for safety issues. Every car company has poorly designed issues that fail on a regular basis, but nothing is done about it.There doesn't need to be deaths for them to issue a recall.
And a leaking exhaust manifold due to cracking has the potential to cause deathsThere doesn't have to BE a death, but there has to be a possibility. Recalls are only issued for safety issues. Every car company has poorly designed issues that fail on a regular basis, but nothing is done about it.
That's up to the NHTSA to decide. Highly unlikely it will leak bad enough to raise CO levels above danger level in cab. If someone was to prove it did, they would have to. But they won't for a defect. I worked for a municipality, that bought Chevy vans. They had to replace over 50 intake manifolds, when Chevy had a poor design, that all leaked. Chevy redesigned, but did not pay the cost of repairs for vehicles with the bad design.And a leaking exhaust manifold due to cracking has the potential to cause deaths
yes. infamous "hemi tick"How did you know they needed replacing - noise or ??
Maybe, but they could still use the same manufacturer/material for hurricane exhaust manifolds. Only time will tell.Well when the Hurricane HO replaces the Hemi in the 2025 models, that issue will be a thing of the past so of course Stellantis won’t re-design it now.
3.0 Hurricane engine is a twin turbocharger design.Maybe, but they could still use the same manufacturer/material for hurricane exhaust manifolds. Only time will tell.
yup3.0 Hurricane engine is a twin turbocharger design.
The turbochargers bolt directly to the cylinder head.
