Last Ram I'll buy
RHut
So now I need my manifold bolts removed/replaced for the 3rd time. First time driver's side but still under extended warranty. Second time passenger side just after extended warranty ended (and they misdiagnosed it as lifter failure). Third time driver's side again-one month after 2 year warranty on the original repair. It's obvious this needs to be a recall item and how can they still not know how to prevent this from happening so often. I love the way my Ram rides and looks. But this issue will probably keep me from ever buying one again (and I'm in the market for a truck for my son now).
I understand, and they all have problems. Things on the manufacturing front are still a mess- when some manufacturers are doubling their allotments for warranty repairs (Stellantis and Ford are two who’ve done that for the 2023 MY), you know things are bad.
Edit: originally said RAM, meant Stellantis.
Could just replace the manifolds with shirty headers, now that you are out of warranty. And not worry about cracked manifolds or broken bolts again. Most 5th gens have cracked manifolds though, not broken bolts.
After one repair failed I would be installing shorty headers. Case closed. That will solve the problem that they just cannot seem to fix.
Sure your warranty may have been covering but not dealing with the hassle and being without your truck for multiple failed repair attempts would be money well spent in the long run if you plan on keeping your truck for awhile.
I have seen several people on this forum that have reported broken bolts before. Maybe not as common but still a thing.
Bolts are not breaking with the tie bars, the manifolds are cracking. Techs claim broken bolts to get paid extra time.
If I’m out of warranty and this happens, that’ll be my move as well
How would replacing broken bolts be more time than replacing the manifolds?
I would think replacing the manifold (and all the crap that goes with doing that) is less work than the same effort (in order to get to said bolt) in addition to getting a frozen in place broken bolt out.
He said extra time as in the manifold are cracked AND the bolts broken so you get paid manifold replacement time AND broken bolt time.
My bolts weren't broken, just two cracked manifolds. Service ticket states replaced both manifolds and new hardware, only labor for the manifolds
Usually the bolts aren't frozen and can be backed out with a pair of pliers.
Read between the lines, techs are "claiming" broken bolts for extra time. In common speak, its called lying, for more money. Techs get paid by the job, broken bolts = additional work which = more money
I understand that. I was asking why it's "extra time" to replace broken bolts, when it's doesn't take extra time.
I see people all the time calling for the manifold bolts to be a recall. This issue will never be a recall. Recalls are for safety issues and a small exhaust leak is not a safety issue.
Not completely true.
"A damaged or faulty exhaust system can cause poisonous fumes to leak into the passenger cabin resulting in serious health and safety issues."
I'm sure if it really was bad and enough complaints something could be done if the exhaust system is not functioning properly and venting under the cab and not at the rear of the vehicle.
Here is a recall from Ford for a similar problem.
They won’t consider it a recall until a certain amount of people die from it. And the courts would have to prove the cause of death is directly from the manifold leak.
I think they should at least extend the warranty like they did with the AAD. That probably won’t happen either.
