theblet
- Feb 8, 2021
O2 spacers worked for my on GM vehicles. The last one I did I daisy chained spark plug non foulers (one drilled out) and it worked like a charm.If you feel that you're getting codes from the headers/cats..it's probably the rear O2 sensors that are throwing it..quick & easy check/fix is to get a couple of O2 spacers. You just thread out the rear O2 sensors, thread in the spacers (0.5"-0.75" length), then thread the O2 sensors back in. This moves the sensors out of the crossover pipes to lower the crossflow/surface area thereby lower its sensitivity and readings..often works. A custom tune/tuner will often just turn them off..but then you'll have problems with emissions testing if you have to do that. Try the O2 spacers.
Just never tried it on and rams.
