I can guarantee you from personal experience, you will only be able to get 5 or 6 Stage 8 clips on..that's just always the case..but they're just really added insurance and not necessary.
DiabloSport will tell you that you can run LTs on a factory tune, but it may run a bit lean..a truck isn't a race car, so a perfect tune isn't critical.
All headers mostly improve horsepower, not necessarily torque, and they push the powerband higher up the rpm band..also, not great for a heavy, lower rpm truck.
BUT..the 5.7 Hemi quite possibly has THE WORST exhaust manifolds EVER..so LTs will definitely make the Hemi breathe and rev better!
I've had Kooks, American, Dynatech in the past. Kooks have issues with collector/ midpipe hookups. Dynatechs are very well fitting.
I plan on adding LTs to my G/T exhaust at some point..but may swap the G/T for the Mopar (Borla) catback.
If you don't have access to a tuner, call HHP (High Horse Performance) and get a DiabloSport tuner and a "custom" tune from them. They will have you send them a datalog (very easily obtained) once you do the ECM swap and tuner install. They'll read your data and be able to optimize your fuel curves, ignition curves, etc, etc..It will help a bit, and give you peace of mind also.
Jealous here!!
