Wow, I'm super unimpressed here. I just sent a message to Borla to see what's up. I ordered a Borla Touring CatBack from RealTruck for my '21 1500 CC Short Bed 5.7. I was able to get the muffler section bolted up and tightened down to the factory mid pipe, but once tightened, it has forced the passenger side muffler outlet pipe to pin itself against the bump stop mount that's welded to the frame. Since there is no adjustability at the mid pipe/muffler section joint, I'm at a loss. Also, no amount of wiggling, loosening and tightening can get the passenger side tip centered in the cut out. Driver side is spot on. Also, there is MAYBE an 1/8 to a 1/4' of clearance between the muffler body and the frame rail. Something just isn't right. Its almost like the passenger side outlet pipe was welded wrong and needs to be rotated counterclockwise from the muffler body.
Hows everyone else's Borla fitment?
