Hi,
I've a 2019 Ram Laramie and always thought I didn't have an air dam because I was of the impression I had the air suspension hence no air dam.
I've been getting a U11E9 Active Grille Shutter (AGS) code but despite replacing the AGS I am getting the same error code 10 months later. I read that the issue may be an Air Dam issue and some people got letters from Ram to get the Dealership to fix it under a warranty. I haven't. I took the attached pics under my truck and to my amateur eye it looks like an air dam. Is it an air dam? I've gone ahead and unplugged it and erased the code using the ODB scanner. I also just took the negative terminal off the battery for an hour to reset truck computer.
Am going about this the right way? I include the truck specs attached. I don't mind if air dam stays unplugged as I want code to clear for state inspection.
Thanks.
Thanks.
