I can vouch for this. I used this exact bulb list for mine, and they all work flawlessly. I paid 20 bucks, I think, for the entire lot of them. I swapped them all out in under an hour this morning. I took a few pics that I'll try and upload a little later. I have to head out shortly.
Also.....As far as the little wires go, I just used my finger nail to push them out to the edge of the little plastic piece before inserting them into the socket, and they line up just fine. You can even adjust them once socketed, barely. Just lift the retention clip/connector with your nail, and use your tiny screwdriver to seat the wire underneath. All of this depends, however, on the overhead console being in your lap.....versus still installed in the truck. Taking the console down, and reinstalling it, were the easiest steps in the whole process. Good luck guys!
Cheers
**Edit**
Here are some pics. I've included a pic of the small screwdriver that I used to get the vanity light covers off. Just push straight in at each of the tab points, prying them open one at a time. There are a total of 4. You'll see them. Make sure you're in all the way before you pry each section, or you risk scratching something. It's easiest to pry the two inside tabs on each cover. It will then pull off.
**Edit**
I just did my 3rd brake and cargo lights. The cargo lights are the same T10 bulbs that I used in everything else. I now have 3 of 10 left over as spares. The 3rd brake light is the same exact sized bulb, only the light output is red. I've included a picture of it already installed in the housing.
