Interior LED Lights swap out possible?
kingkasc
Purchased my 19 midnight last week and it doesn't have interior leds. Does anyone have a link to swap these old fashion yellow's for led's please? thanks
Also what tools did you need to remove the covers? going to amazon everything lol
Your the man! did you need 2 lights for upfront and 2 in the back? also did this give you any error codes etc? thanks!!
2 up front and the rear is a different bulb I cant remember the bulb #, I used plastic car kit tools
thanks! I almost ordered 2 lol, when you get a chance can you please check your amazon order history pretty please! lol
backseat dome light is the 41mm? thanks again ( ordering the second you confirm!)
Check this out at Amazon.com
SiriusLED Extremely Bright 400 Lumens 3020 Chipset Canbus Error Free LED Bulbs for Interior Car Lights License Plate Dome Trunk Courtesy 1.72” 41MM 42MM Festoon 211-2 569 578 6000K Xenon White https://www.amazon.com/dp/B01AHVNDZK/ref=cm_sw_r_other_apa_HbRLBbPCKSVPK
Question, I replaced my interior lights on my 2011 with LED's and the back seat light wouldnt turn on if the truck wasn't on ( even though you press it to turn it on). Can you confirm that it will turn on if you have the truck off, otherwise it's a deal breaker for me swapping in the LED's.
I'm waiting on a definitive answer on which bulbs for which lights and how people are accessing the front map light bulbs before I order.
So I replaced them all today and it was very easy. Just pop the plastic cover pieces off, pull the old bulbs out and plug the new ones in. Same with the back. No errors and looks a million times better. The bulbs he posted worked perfectly.
Can you please take a picture pointing what part your suppose to pry open to get to the bulbs? I replaced my cargo bed lights within a few minutes but not sure where to open up the interior lights at. Thanks!!
Are all of you guys replacing your lights have BigHorns ?
This is where I'm stuck at. How do I remove the silver piece to get to the bulb?
