Installed 3.5 inch Rough Country Lift
I just got a 2023 1500 big horn built to serve edition with the factory 1" lift offroad package. Ive been highly contemplating getting the n3 3.5" loaded struts and uca's from rc for the front and n3 0-3" shocks for the rear and hoping that would make it level since the bts edition comes with a 1" lift from the springs all the way around. My math says that if I remove the 1" lift struts from the front and replaced it with a 3.5" than the 1" lift in the back will make it equal out to a 2.5" lift in the front with having the factory bts offroad package.
I've got a 2021 RAM 1500 Laramie Sport - stock 20" wheels w/275/55r20 Falken WildPeak AT4's. . .thinking of the RC 3.5" lift with M1 struts w/rear shocks. The kit (Rough Country SKU: 31440) does not show it has rear lift spacers. . I'm worried that this will raise the front of the truck and not the rear to make it uneven. I read the Motofab spacers comment about adding a 2-3" spacer to rear. . .will it work with this kit? Do you recommend it? Thanks in advance for your input/advice.
The 3.5" kit comes with a rear spring spacer, not sure how big i would assume 1"-2". Im sure that spacer would work and would probably keep the truck raked but you could also go with a whole new rear coil, the ones I've seen are like 1.5"-2" of lift.
is your truck a V6 or V8? I wanted to get the 3.5 lift for my 21 ram but its saying that it does not work with the 3.6
I have a v6 with RC 3.5” M1. I lowered it by 1 clip to compensate for the weight difference from the v8. I’ve had it for almost 2 years with no issues.
