I hate Ash trees..
WXman
Kentucky, USA
I guess more specifically I should say that I hate the Emerald Ash Borer which is the pest that has killed all of the Ash trees in this part of the country. We had high wind yesterday and a dead Ash tree broke about 30 ft above the ground. The top half then did a spear into the ground with lots of loose branches hanging above it tangled up into other trees. I tried to untangle the mess with a 29 HP tractor. No dice. Tried to do it with the EcoD, rear locker engaged, 4-low. No dice. I guess I'm going to ask the neighbor if I can borrow her 5-series John Deere. This is ridiculous. I took it easy because I didn't want to break the truck but clearly with the tires spinning it wasn't working anyhow.
John Brereton
Sounds like you just need to break the saw out
Sent from my Pixel 2 XL using Tapatalk
John Brereton
That would probably be a big hole to dig before it starts moving
WXman
Kentucky, USA
Yeah my saw doesn't have a long enough bar to cut it. And even if it did it's a dangerous cut because it's laying up against the trunk. No way to know which direction it would fall during the cut. I'm going to try digging around the base a little and then either hit it with the neighbor's big 4x4 Deere or daisy-chain a couple of pickup trucks together and drag it out. Bad thing about it is that I'm getting estimates from fencing crews to run a fence through this exact area so I gotta' get it cleaned up and safe soon.
devildodge
Moderator
Central Pennsylvania
I can not believe it is that far in the ground. But guess I am not there. Loosen the ground or cut the tree...if the neighbors tractor doesnt work
