HuskerThor
- Jan 30, 2019
Does anyone know if the ridiculous feature that instantly slams on the emergency brake if your backing up with the door open can be bi-passed? I also had it happen when my rear park sense thought I was too close to an object. I have to squeeze my truck into my garage and often do this. It is driving me crazy.
That’s the first time I’ve heard that. Thanks for posting. I will try that next time.@Rammit Old thread, but I found this in the Owners Manual and think this is what you're looking for (with regard to backing with the door open).
SafeHold
SafeHold is a safety feature of the Electric Park Brake System that will engage the park brake automatically if the vehicle is left unsecured while the ignition is in ON/RUN.
For automatic transmissions, the park brake will automatically engage if all of the following conditions are met:
• The vehicle is at a standstill.
• There is no attempt to depress the brake pedal or acceler-ator pedal.
• The seat belt is unbuckled.
• The driver door is open.
SafeHold can be temporarily bypassed by pushing the Electric Park Brake Switch while the driver door is open. Once manually bypassed, SafeHold will be enabled again once the vehicle reaches 12 mph (20 km/h) or the ignition is turned to the OFF position and back to ON again.
Easiest solution for me was to buy a 3" seat belt extender. It's always plugged in and it won't slam into park if you open door.Does anyone know if the ridiculous feature that instantly slams on the emergency brake if your backing up with the door open can be bi-passed? I also had it happen when my rear park sense thought I was too close to an object. I have to squeeze my truck into my garage and often do this. It is driving me crazy.
I know this is an old subject, but it just helped me a lot. Damn auto brake scared the hell out of me and I was still 20 feet away from an obstacle. Thank you for the tip!You can disable the automatic breaking function (I'm not sure if you are asking this or asking of you can disable if from occurring only when you open a door, which I dont think is possible).
On the 12 inch Uconnect, there is a option in the settings menu, under the safety and driving assistance menu
