How to: modify wheel wells for larger tires/Negative offsets
This would have been a nice thread to see before I massacred my inner fender liners.
Has anyone done any more metal trimming than just the tab? As in maybe part of the pinch weld, maybe going back as far as one of those bolts at the bottom. On my 4th gen 2500 I did some pinch weld trimming for 37s. So was just wanting to see if anyone has done more than just the tab.....
I have RC 3.5 lift, and am about to put on TRX wheels and 305/70R18 Yokahoma Geolander MTs (basically almost the same size as the factory TRX tires. I have seen most of the threads from people installing the TRX wheels/tires on with 1.5" spacers and it seems to be fine with the normal tab mod that this thread is mostly about. However, I have 2" spacers right now with current setup. I know maybe one person did it with 2" , but anyways, i just wanted to know incase i need to trim back the pinch weld too.
Yes, I had to trim back to the first bolt. The 37s still rub a bit, -44 offset.
Would you happen to have any pictures to have an idea what was done
Months late, but I’m waiting to see pics of the bend up method.
Already cut my wannabe flares off in irder to maintain the rocker corner “protector”. Still getting very minor run backing up into my sloped driveway at full lock.
2019 Ram 1500 Bighorn Blue Streak. Appearance package. Blacked out emblems. Rough Country 6 inch lift with N3 struts all around. 20x10 -25 Toxic Punishers in Gunmetal. 35/12.50r20 Gladiator XComp A/Ts.
The procedure is detailed with pics at the beginning of this thread
That procedure is for cutting off the metal tab, not bending it up. I want to see the bend.
It’s pretty thin metal …. I just straightened it out with pliers, and then bent it straight up …. Drilled a new hole for the liner, just below the old one …. It’s super easy …. You’re just bending instead of cutting …. I thought somewhere in these 89 pages, somebody detailed bending …. Been a couple years since I did mine …. Hadn’t been back here in a while …. Good luck …. Sorry, I didn’t take any picks
No problem! Someone else asked for pics of it but no one posted any.
Thanks! I don’t like the ziptie look so I’ll be going the bendy route.
Just did this today, but instead of cutting I did the bend route. Also instead of using zip ties I drilled a hole into the bent metal and used the existing hole from the original black retaining plug, used some nylon retaining clips that I had left over from a previous project. All in all took 20-30 combined for both sides. No hacking necessary!
Thanks @19BlkRam for the write up.
Thank you for this write up. I had the 285/60/20 tires removed and put 35/12.5/20 Falken Wildpeaks on today and they rubbed fairly hard on the drivers side. Took me maybe an hour to do it. I had to remove the mopar mudflaps from the front but now have plenty of room for the flat style duraflaps that should be showing up in the mail tomorrow. Truck is a 2020 limited ORP with the links and daystars up front. Love the look.
What offset is this?
Seems like off set matter ALOT when it comes to fitting the rim/tire combo regardless of the list. I had 35x12.5R20 Ridge Grapplers with -8 offset installed with my 4inch bds a while back with zero trimming and zero rubbing since day one. I am getting bored with the set up and wanting to try the new recon grapplers in 37x12.5. Looks like I will have to take off the front lip with air dam delete to clear the front. Back should just be enough. Havent pulled the trigger yet still trying to dig around some more. Has anyone done a 37's on a 4inch?
I don’t think you’re going to clear 37’s on a 4” lift I’ve always seen 6”+ lifts on 37’s and still requires trimming depending on offset.
Good info in this thread…..
Thanks for the link. I have read his post, I dont think people with air suspension has the same options as he did. His wheel off sets look way different that what im running. Zero tire poke, now that I look at his ram the 37's seem almost too big but theres also different size 37's depending on the tire manufacture. So many factors to consider, i might just say f it and bit the bullet and trim what ever is needed to make the 37 recons fit.
Brave, why the jump to 37’s ?? For looks or do you plan on crawling with your truck?
Just got looks/bored with the set up and wanting to try something new. We have a off road/state park within an hour from where i live in norcal. I take the truck out there every now and then for fun and some light off roading. IMO the air suspension is great for road/towing, not the best for hardcore crawling or offroading. Its too stiff for that.
Just got looks/bored with the set up and wanting to try something new. We have an off road/state park within an hour from where i live in norcal. I take the truck out there every now and then for fun and some light off roading. IMO the air suspension is great for road/towing, not the best for hardcore crawling or offroading. Its too stiff for that.
I feel that, and I agree 100% these air suspension truck suck badly off road. I wish I did better homework prior to my purchase a few years ago. I would have gotten a rebel instead of this limited.
Hey Carlos, Do you have any pictures of how much you trimmed?
I'm tempted to put 37x12.5 with a similar offset. I was looking and may take the bolt closest to the wheel and drill another hole right between the two bolts to move it back. The trim right up to it. I have 24x12's with -51mm, the 35x12.50's run with my 6" lift but I hate how much gap is in the wheel well.
Also has anyone trimmed the front bumper? Curious how to not ruin the chrome!
