cmdr bobert
 - Nov 29, 2018
It is my understanding that the eTorque only helps with stop and go with extra torque "push" to get the truck moving from a stop. It that is the case, it certainly would only help "city" stop and go mileage and not highway mileage - it doesn't just automatically kick in during highway driving like a hybrid vehicle does and therefore can't help in highway driving mpg.
The eTorque generator/electric motor is larger than the standard alternator and produces a lot of torque as an electric motor but also needs a lot of HP to turn in generator mode. Generator mode hopefully is mostly done in regenerative braking or slowing down mode but if not, it is drawing a lot more power from the engine than the standard alternator would.
Power in = Power out. If you are adding extra power/torque to the wheels at the start from a stop than you are using the generated stored energy from the battery that must have been generated and stored there and must be replaced by generated and stored energy for the next "boost".
Again, if everything is working properly and energy was generated while slowing down or stopping that it is a win-win and the energy was generated for free and no power was used from the engine = more starting take off boost with less gasoline fuel consumption.
If everything is not working properly and the energy is not being completely replaced while slowing down or braking/stopping than the power of the engine is used to generate the electricity to recharge the battery.
I am sure that the eTorque generator turns harder that the standard alternator for quick charging/regeneration and would hope that it is "variable" for general system charging.
My other car is a Lincoln MKZ Hybrid, a great comfortable ride that gets an average 40 mpg with no sacrifice in performance compared to the smaller standard gas engine.
OK, then explain Ram's website. Here's a screen shot. Notice the benefits they tout are best in class fuel economy and driving range.
