Horrible Smell coming from The AC
Big2019Ram
Has anyone noticed a dry Mildew smell coming from their vents once the Ac is turned on? I have really been noticing it being very strong lately, but only when the AC is Blowing.
MannymanX
5thGenRams Supporter
AzZona
It's a known problem with new FCA vehicles.
I traded my 2018 Pacifica because of that and my Ram did the same thing pretty much since day 1.
I visit the dealer every few months for this reason.
I actually went to the dealer to address this today and scheduled an appointment for next Friday. I will probably have them re-charge the system and clean the AC radiator from bacteria.
When my service adviser smelled it his reaction was so funny :D "Dude, IT SMELLS LIKE BUTT", His words.
I think the system is undercharged from the factory and that's what causing this issue.
Will keep you posted.
Big2019Ram
Thank you so much and please DO. I will be taking mine in also and having them check it.
dano257
New Jersey
I had a previous car with that problem. The A/C condensation drain was blocked and it smelled terrible. After that was cleaned, after a day or two it was back to normal. When I ran the A/C there was no "puddle" under the car which was an indication that the drain line was clogged. Just a thought.
Charon
Came here to post about this issue. I replace my filter with a NAPA gold filter. It didn't fix it, though the old one was disgusting.
I shoved about a foot of drip hose down my condenser drain, No luck.
Now the next question would be how to drain the A/C condensation?
It's the small hose poking out on your firewall on the passenger side. fairly close to the engine.
MannymanX
AzZona
IT SMELLS SO BAD!!! I DON'T KNOW WHAT TO DO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
mikeru82
The Palouse
This has been a problem for as long as they have been putting A/C in cars. There are methods for eliminating this. Here's one way...
J-Cooz
My VW golf had this problem really bad. I took it to the dealer under warranty and they cleaned it using ozone. I'd take it back to the dealer and have them clean it.
I have zero smells on my 2019
wwwhiz
I’ve had this issue on a VW Atlas, most recently. Ended up learning that I need to turn off the climate system/fan when running through a car wash. The high-pressure water and vapor saturate the system internally, leading to this unbearable smell in a day or two.
MannymanX
AzZona
Have not washed my truck for two weeks now. Smell still comes and goes... IDK... Doesn't look like this is the problem...
RamGuy32
I have the same problem and these are some of the issues that I experienced and a couple of things that helped.
1. As someone said above, NEVER go through a car wash with the fans on. It sucks moisture into the system and then doesn't dry unless you go for a long drive.
2. Turn off your AC about 2-3 minutes before you get home and let it dry out the system.
3. My problem was that I back down a fairly steep driveway so the front of my truck is pointed up. In the summer, I just have to pull in and allow the drain to stay downhill. When I would back in I never had condensation puddles under the truck. But when I pull down the driveway, I now get a good cup or two of water that runs out.
Hope that helps!
