Hemi Lawsuit May 2022 Discussion
I was told by a mechanic friend(non-dealer) that the tapping at cold start was the hydraulic lifters just before the oil pressure builds enough to get oil in them. Usually happens more often if the truck sits for a couple or more days.
See post #38 above.
Percentage wise, the number of engines negativity effected by the "hemi tick" are low when you look at total production. I don't think I've personally known anyone who has to have their engine replaced, or had a cam live wiped from it, and I've been part of the Mopar community since before the modern Hemi was even in development.
Back 15 years ago, the biggest issue was the timing chain tensioners on the early 5.7s failing. I know a couple guys who had to get their timing chains replaced under warranty, and a few who pre-emptively replaced them to prevent issues.
2019 RAM 1500 w/ 133k miles developed a tick on startup around 75k. Truck is now sitting at dealership needing a new engine. Lifter & cam failure in cylinder 8.
This post didn't age well, as a local friend has his truck in the shop now because of lifter failure. He thought it was just leaking manifold
I've got a 19 ram 1500 as well with the tik at 160k miles , very frustrating . It just started a few days ago , no warranty and trying to figure out if I should order a rebuild kit on ebay , or which kit I should grt, cause God knows that won't do anything to cover it ...
are you sure it's not exhaust manifold bolts? it's pretty easy to crawl under and check them. I haven't read through all the posts, so might be missing something. I had a 2014 that had to have manifold bolts replaced twice. It usually ends up being the ones toward the rear. and easy to see if the heat shield is loose.
Figured since I didn't see a dedicated thread I'd make one.
Everyone see the latest class action lawsuit regarding the Hemi?
They should at least cover over half of the repair cost.
