Richard320
- Aug 3, 2019
Some kind of adaptive memory based on driving style.What does this do/reset?
It's a throttle pedal calibration procedure. People will notice a difference in throttle response, but the more you drive, it relearns your driving habits and reverts back to what it was before. I drive my truck very aggressively most of the time. Can't say I've noticed any issues. Those who drive "normal" are work on improving gas mileage are probably effected more.What does this do/reset?
This is all true, but the other other part of the equation (and part of what a Pedal Commander or similar corrects) is the throttle response speed. The stock throttle response is a bit sluggish and has a bit of a delay. You can stomp on the pedal, theoretically opening the throttle body 100%, but there is a delay as the throttle body slowly opens. It is not an instant response. The Pedal Commander can remove this delay, so when the pedal is pushed, the throttle body responds instantly. Sprint Booster has an old video available that demonstrates this well.A pedal commanderz or similar device doesn't give the truck more power. It just changed how the throttle.body reacts to pedal input. For examples stock, of you push gas pedal down halfway, theoretically the throttle body opens half way. With the pedal commanderz depending on level you choose, if you push gas pedal down halfway, it may open throttle body 3/4 of the way. So if you are just more aggressive in your throttle you can achieve similar results, just have o.gice.more throttle input with your foot.
My Built to Serve with Vararam and Borla ATAK gave me a 6.1 0-60 time using the TazerDT timer.Disconnected my battery and then drove normally for a few days. Feels a bit better but still seems slow with consistent 7.5-7.8 sec 0-60 times. Watching other 5th Gen eTorque 0-60 videos with 3.21’s running low 6’s. Quite a difference for sure.
Anybody else here time any 0-60 runs? I especially would be interested in seeing data from G/T performance pages since I’m set up with the same exhaust and CAI. Doubt that makes any difference but just curious to see what others run with a similar setup.
Before I take my truck in I wanna make sure there really is a problem. I hate dealing with service departments especially for something like this. Hope to figure it out on my own.
Does your Laramie have the ORP like his Back Country? Different wheels and tires, different options, trucks weigh different. Lots of factors involved. He probably drives different than you as well. The real test would be swapping trucks for a tank of fuel and see what happensMy buddy and I just got new Rams. His is a Backcountry. Mine is a Laramie. We live in the same town and fuel up at the same station and drive the same general roads to and from work. His truck is getting about 14 MPG and mine is seeing 17.5. This is per the dash display, not hand calculated, but nevertheless it's relevant for this convo. Both of us have the non-eTorque Hemis.
Something seems to be dragging his truck down compared to mine. He says it feels the same in terms of power, but I don't think it should be seeing significantly lower fuel economy like that. Odd......
I will say that my 2020 EcoDiesel with 3.92 gears felt like a monster compared to this Hemi 3.21 truck. The trans shifted better and the engine felt really strong. When I go WOT on this truck it feels like a parachute is connected.
You'd be surprised how much driving style can make a difference. Are the gear sets the same between the trucks? You can look at your payload capacity on the door frame to help determine if the weights are similar.He and I both drive like old men due to fuel prices and our careers. Lol. My truck doesn't have skid plates like his. But his truck doesn't have some of the options mine has. Curb weights are likely almost identical. I'd say the only significant difference is the tires. I have 20s with H/T tires. His, being a Backcountry, gets A/T tires I assume.
I've run mid 6's 0-60 in my GT, per the Performance Pages timer. I believe that day I had a full tank of gas, and the wife was along for the ride, so I'm sure there's room for improvement. I don't think I ever got below 6 seconds in my Big Horn, which was much less optioned out than this truck, my point being that these trucks will never be rocket ships. Still, you're a second slower than you should be. Have you possibly confirmed the fluid levels in your rear diff and transmission? Tire pressures? No disrespect intended with these questions, but I have read posts where other members have found those fluids low or in poor condition. Also, just out of curiosity, what does your payload sticker read?Disconnected my battery and then drove normally for a few days. Feels a bit better but still seems slow with consistent 7.5-7.8 sec 0-60 times. Watching other 5th Gen eTorque 0-60 videos with 3.21’s running low 6’s. Quite a difference for sure.
That should have zero effect on 0-60 times.Get a throttle commander. It makes a pretty big difference in instance off the line feel with no delay
Already added one. See above.Get a throttle commander. It makes a pretty big difference in instance off the line feel with no delay
Not as many variable as you want to think. Uses GPS and accelerometer. Launch in 4-hi so there is no wheel spin, and that removes the biggest variable. Obviously weather conditions and altitude will play a part as none of them correct for that like a Dyno tries to. But we are talking tenths of a second or less, not a full secondNo. But he is basing a lot of this off feel, I feel like. As 0-60 times using apps have a lot of variables to play.
It makes the truck “feel” much better once it’s installed.
