Ready Go
I'm using an Autel 12-8 Gateway Bypass Cable and OBDLink MX+ on a 2024 Ram 1500 DT.
I did a Backup to AlfaOBD, an Upload to Google Drive, and a Configuration Change to change the Foglight Dropout to "NO" and everything seemed fine that I could tell.
The Foglight Dropout worked and the Fogs stay on with the Highbeams.
But when I went to check Google Drive to look at all the data (I am looking for info that might allow me to adjust the Exterior Lights "Battery Saver" timer from OEM setting of 8 minutes to 2 minutes), then only data that shows is for the Foglight Dropout Enable Configuration Change that I made! I've repeated this and it's the same every time!
The App worked to do what I wanted so far, but I feel uncomfortable trying anything more complicated without a Google Drive upload to look at and back it up.
Anybody know if I'm doing something wrong..or if it's because my 2024 DT 1500 isn't fully supported yet??
Before I purchased everything, I emailed AlfaOBD info support to ask if the 2024 DT 1500 was supported and they said "not fully supported, but most things should work through the closest year model ("BC DT MY2022+ PowerNet", in my case).
I have sent them a follow-up email asking for help on this issue, but thought I'd ask here also.
@Jimmy07 any thoughts?
THANKS to ALL!!
THANKS to ALL!!
