Jako
I just added the Hellwig rear sway bar. Thanks to everyone who recommended it (and the links to the AAFES store). I used the Hellwig heavy duty end-links.
I set the end-links to the middle hole in the sway bar. I've just driven about 20 minutes...and am amazed at the difference. What a phenomenal, and easy, upgrade.
Nits: The kit is a generic kit. I re-used my upper end-link bolt (had to, since there's a welded nut for it to thread into, metric, different than the SAE threaded hardware), and had to forego the inner washer. I figured the large flat mounting surface would suffice...
- c3k
- Forum: Suspension
Hey guys
I got a 2019 Laramie Crew 5.7L 4x4
I just got back from Hellwig to let you know about their swaybar setups. We confirmed that the previous generation swaybar fits the 2019 like a glove. The ride quality has improved a lot and feels so much more stable in and out of corners. The swaybar is a lot more beffy and solid compared to OEM which comes hollow. Definitely recommend the product. Here are some pictures
- Mikhail19Laramie
- Forum: Suspension
Update 4-13-20
Sorry folks that are just getting here, seems like realtruck has caught on and has updated the price to $305, hopefully everyone that got an order through will still get the sway bar!
So came across this the other day on realtruck.com
Hellwig part#7883 for $125 + free shipping
its the same as part#7709 except it come with longer links for lifted truck, if your truck isn't lifted just re-use stock links.
link...
link...
- myles
- Forum: 5th Gen Modifications/Accessories
Hey,
Been looking to pick up one of these for my '21 1500.
The 7793 is going for close to $400 while the 7709 goes for around $260
What are the differences between these two bars, both say they fit a '21 RAM
Thanks!
Thanks!
- tuffycycle
- Forum: Suspension
Not long after purchasing my 2019 Ram Rebel I started hearing a rattle coming from my front suspension. I visited the forum sites and Facebook groups to find that there were a few others with similar stories. I saw quite a few who pointed to the sway bar link pins. So I started there first and found that there are no aftermarket companies who make an improved design, specifically for the 1500s, over the ever-failing stock design. While researching, a member from this forum pointed out a possible solution from a company who had a different design that used heim joints. The issue with...
- JayBee2019
- sway bar bushing sway bar link
- Forum: Suspension
Well after installing my new sway bar I contacted Hellwig for a return shipping label for the old one but they told me to just keep it.
I decided to scrub it down with hot water and a scotch brite pad. Too my surprise all the rust came off right down to the original finish and looks almost new again. A good coat of quality paint which will better than the factory finish and it will be perfectly fine to use again. I’ll likely list it in the classifieds as I don’t need a spare.
Will shoot you a pm, I’ll save you the trouble of...
