Did you ever end up getting one? Heard Dark mode only works while vehicle is in park ..not motion. DumbDoes anybody have a video of the Tazer dark mode in action? I'd like to see it working before I fork over the cash for one.
2020 problem still not addressed. if you turn on the DRL all the lights will always be on. I couldnt shut off the lights at all.....Daytime turned off but they stay on....and then you can use the manual light switch however manual or auto.I can't seem to get my headlights to turn all the way off. I went to a drive-in movie and had to keep my truck shut off with no sound due to this. Does anyone know how to turn off all exterior lighting with the vehicle running and/or in accessory mode? I can't get the "outline" around the headlights to shut off, I've tried everything I can think of.
if you turn off daytime running....uncheck da box...you can use the light switch, but if you check DRLs box all the lights will NOT turn off ever while running. Proven fact. open issue.Does anyone know if FCA is working on a fix for the issue of not being able to turn off the headlights while the truck is moving? Every time I arrive at a campground late at night I feel terrible. In every other vehicle I've ever had, I could turn off the headlights and find my campsite using just the running lights (or fog lights, or both). Having those LEDs blazing away is a real problem for lots of us that tow trailers or have truck campers and arrive after dark... I can't use the Ebrake when I'm driving 10 mph...
The headlights run at 50% brightness when used as DRLs. So the switch still makes a difference, but it won’t shut them off completely without disabling their use as DRLs.if you turn off daytime running....uncheck da box...you can use the light switch, but if you check DRLs box all the lights will NOT turn off ever while running. Proven fact. open issue.
I looked all over the Uconnect and there’s no such featureSounds like you had DRL turned on in UConnect. With engine running the headlights would then be on in a low mode.
Just go into UConnect and disable Daytime Running Lights.
My thoughts exactly.at the movies, pop the hood, drape an old t shirt over each headlight, close hood securing shirts. bam problem solved (only at the drive in).
You mean...drape both your and her shirt over each headlight...it is a drive thru after allat the movies, pop the hood, drape an old t shirt over each headlight, close hood securing shirts. bam problem solved (only at the drive in).
