Can anyone confirm if it’s counterclockwise to lower the beam and clockwise to raise it? I don’t want to just start turning away and realize it’s wrong.
Same as others said...aim at a wall and watch as you turn. Count your turns if you are afraid of losing the setting. It's not rocket science. Just do it.Can anyone confirm if it’s counterclockwise to lower the beam and clockwise to raise it? I don’t want to just start turning away and realize it’s wrong.
My observations with Ford is their led headlights are the worst for stray light at oncoming traffic. As well the Ford Explorer I drive for work has led and it totally sucks in brightness compared to the Rams. Frick I hate FordThanks for these posts. I looked at my new RAM 1500 and didn't think it was too straight forward. I did want to add something, particularly for the person who put a 2.5 inch lift kit on his. I know the books all say to aim it at a wall. That is a good starting point. For those of us with access to dark roads finalizing out there is best.
You should always be able to see at least 6 seconds ahead of where you are, regardless of conditions. Raising hi beams to give 6 seconds of lead at 80 mph is really pushing it for many rides with only 2 light fixtures. At worst if you set those high beams well then the low beams will blind oncoming drivers.
You just have to find a balance to where you can see far enough ahead of you to be safe and not be a nuisance to other drivers. In my recent '17 Ford Explorer and my sporty Jag putting the lights up enough to give me 6 seconds at 80mph didn't cause any issues. My truck at work is on a F-450 chassis so the light fixtures are higher off of the ground than passenger cars. On that, even setting the high beams for 6 seconds at 70 mph causes oncoming cars to flash their hi beams at us when we already have our low beams on. Like I said, have to find that balance. Especially true for lifted rides. 65 mph is fast enough for F-450's at night, even ambulances.
I am headed out now to check my new twuk's night lighting out. Appreciate the guidance!!
Have you tried covering one light and using a mark on the opposing wall? Otherwise it’s tough to see sometimes.I have the same allen head looking adjustment. I turn and turn and turn both directions with no change.
How much is a lot? I turned 8x and nothing... Like 20 rotations?My truck 2021 Bighorn 1500 2wd. Just my 2 cents on this. Installed 2.5 moto fab leveling kit. Headlight obviously now aimed too high. My experience with adjustment.
7/32 allen head socket with long extention.
Turn counter clockwise to lower.. a lot.
It appears a Phillips head screwdriver will also work but clearance for me was tight so I used an allen head socket.
I had a similar problem...turned about 6x due to my new LED bulbs in my halogen Reflectors...no change. Am I turning the incorrect screw?How much is a lot? I turned 8x and nothing... Like 20 rotations?
I had a similar problem...turned about 6x due to my new LED bulbs in my halogen Reflectors...no change. Am I turning the incorrect screw? The one I'm turning is flat facing up and it's moving the gear looking part under it...I have the same allen head looking adjustment. I turn and turn and turn both directions with no change.
I know it’s “done all the time”, but one reason LED retrofits into halogen reflectors are illegal is because the bulb dimensions and directional light output of the LEDs are so different from the OE bulbs (for which the housings were specifically designed) as to make them incompatible (i.e. horrible glare) and often impossible to “aim”.I had a similar problem...turned about 6x due to my new LED bulbs in my halogen Reflectors...no change. Am I turning the incorrect screw?
That's a good point, however this is the first time I've ever had an issue with LEDs in a reflector housing. I wonder if it's because I got a different brand than what I usually buy...I know it’s “done all the time”, but one reason LED retrofits into halogen reflectors are illegal is because the bulb dimensions and directional light output of the LEDs are so different from the OE bulbs (for which the housings were specifically designed) as to make them incompatible (i.e. horrible glare) and often impossible to “aim”.
That said, I know it’s expensive to do a proper headlight conversion, and I’m hoping someone with halogen headlights here can chime in regarding successful adjustments.
Could be...especially if they’re not specifically designed for the 5th gen Ram housing.That's a good point, however this is the first time I've ever had an issue with LEDs in a reflector housing. I wonder if it's because I got a different brand than what I usually buy...
Just an update...I didn't drive after making the headlight adjustments. Just took my Ram for a spin with my new Auxito $36 led headlights (lol). Everything is perfect...more light output without blinding anyone..good beam pattern. I can't believe ppl spend $100-$200 on LED headlights lmao!Could be...especially if they’re not specifically designed for the 5th gen Ram housing.
When you get a chance, could you measure yours since you adjusted them? I didnt think about it before putting my level on and i was burning everyones retina last night on my ride home. If you could measure the distance you are from the wall and how high up it is. I hate being that guy lol.I did mine I used my garage door. I pulled up and marked a spot for the wheels and then put masking taoe where they shined before the level. Then after adjusted to the same marks after.
