The auto high beam is selected in the radio settings, and the turn signal stalk is pushed forward?Well, the auto high beams was short lived. It does not seem to be working now...or at least the message showing they are active it not showing up on the center instrument cluster display. Any thoughts on that @Jimmy07 ?
Yessir. The radio button is still there and showing active. Yesterday when I pushed it forward I got the "auto high beams active" now it is just switching the high beam on when I press it forward.The auto high beam is selected in the radio settings, and the turn signal stalk is pushed forward?
I mention this but it is likely you know, the vehicle has to be moving, I think around 15 MPH or faster before the auto-high beams will come on.Oddly enough I went back out in the evening it is showed to be working. It was dark enough that he auto headlights came on but no so dark the auto high beams activated. Weird.
That is a bit far but I do live in similar conditions, total darkness but the homes are far back from the road so they don't have an influence. Street lighting at cross streets does not cause a false positive nor does driving towards a traffic signal. The only reflection I can get is from road signs and low-hanging tree branches. But the 2022 doesn't have the false positive as my 2013 did.Around Houghton and Higgins lakes. Pure darkness without lights, so porch lights trigger it too.
I never thought about that, but it's weird that all 3 vehicles that i've had with that option were like that.That is a bit far but I do live in similar conditions, total darkness but the homes are far back from the road so they don't have an influence. Street lighting at cross streets does not cause a false positive nor does driving towards a traffic signal. The only reflection I can get is from road signs and low-hanging tree branches. But the 2022 doesn't have the false positive as my 2013 did.
The only thing I can think of, and this comes from a recent windshield replacement (on my wife's car) is the calibration of the windshield sensors/camera. I would imagine going to the dealer seeking a recalibration would be met with typical BS but it may be worth a try.
I did not know that, thank you. Thank you. Does that mean that if stopped and you hit the high beams they will switch regardless the time of day?I mention this but it is likely you know, the vehicle has to be moving, I think around 15 MPH or faster before the auto-high beams will come on.
Headlights don't even have to be on to flash high beams, with or without the auto feature. when you pull the stick, the highs come on.I did not know that, thank you. Thank you. Does that mean that if stopped and you hit the high beams they will switch regardless the time of day?
I don't know why my 2022 owner's manual doesn't mention the traveling speed requirement for auto-high beams to turn on, in my 2015 OM, they mention the travel speed of 20 MPH or greater, and in the 2013 OM, they mention a speed of 25MPH or greater.I did not know that, thank you. Thank you. Does that mean that if stopped and you hit the high beams they will switch regardless the time of day?
I found these three items of possible causes in my 2022 owners manual under the section "AUTOMATIC HIGH BEAM HEADLAMP CONTROL — IF EQUIPPED"I never thought about that, but it's weird that all 3 vehicles that i've had with that option were like that.
That is interesting. Thank you for that. But being that it resets every ignition cycle, I will just stay manual. I don't mind the old fashioned way I did it for 40 years before that option.I found these three items of possible causes in my 2022 owners manual under the section "AUTOMATIC HIGH BEAM HEADLAMP CONTROL — IF EQUIPPED"
1. Broken, muddy, or obstructed headlights and taillights of vehicles in the field of view will cause headlights to remain on longer (closer to the vehicle). Also, dirt, film, and other obstructions on the windshield or camera lens will cause the system to function improperly.
2. If the windshield or Automatic High Beam Headlamp Control mirror is replaced, the mirror must be re-aimed to ensure proper performance. See a local authorized dealer.
3. To opt out of the Advanced Auto High Beam Sensitivity Control (default) and enter Reduced High Beam Sensitivity Control (not recommended), toggle the high beam lever six full on/off cycles within 10 seconds of placing the ignition in the ON position. The system will return to the default setting upon placing the ignition in
the OFF position.
I did not have a windshield replaced on any of my RAMs nor did I use products like Rain-X that could cause issues with sensing on-coming lights. I forgot to mention that my 2015 RAM 3500 has the same false positives as did my 2013. I hope you find a solution.
He was directing that to me, because I was saying how they are too sensitive and constantly dim from road sign reflections. It would be nice if it didn't reset sesitivity every time. It's not worth the hassle to set every time, so I just turn the auto function off.I think it only resets the sensitivity setting. The auto high beams will work as long as the stalk is pushed forward and it is set in the radio interface.
Hey @Jimmy07 looks like it worked. I have not been out after dark to actually see it, but I do get the alert on screen that auto high beams is active. Thank you! Would you recommend using the JT setting for future adds or does it depend?
I really appreciate you chiming in to help. I know AlfaODB is your speciality but good to know you know something about JScan too!
what needs to be done to add this feature with obd scanner tool. can you still use the jeep to make these needed changesHe was directing that to me, because I was saying how they are too sensitive and constantly dim from road sign reflections. It would be nice if it didn't reset sesitivity every time. It's not worth the hassle to set every time, so I just turn the auto function off.
