The wattage isn't really what determines the volume, the wattage is in the amp, and it's set in a factory system. Most any of the aftermarket speakers will handle the factory amp wattage... thus how much wattage the speakers will handle will have little effect on the volume. The volume is determined by the sensitivity and the resistance of the speaker, which is why all the speakers we have been testing are higher in sensitivity and of the correct resistance so that we don't over-drive the amp. We've no issues improving sound quality with the factory system by swapping out speakers.
The factory system does not need more power to play loud... it's plenty loud in these trucks. Now... if you grab a speaker with low sensitivity, such as the JL Audio that I tested, this is a speaker that needs more power to sound it's best, and to produce the same SPL as the factory speakers. The JL is not designed for lower power like the Infinity, FaitalPRO, Hertz, Kicker and maybe a few others that are used frequently in factory replacement speaker systems. Most of us don't want to have to change out our headunit, as we like the factory unit, and we like the factory look. Recommending replacing the headunit is a serious no go for most of us, not to even get into the fact hardly anyone makes anything that would not require some very serious custom work to make it fit and look halfway respectable. Then you have a WHOLE lot more going on with the factory headunits than a radio... you have vehicle settings involved as well... you just can't replace the headunits in these new vehicles. Factory headunit to aftermarket amp... yes... that works and many of us do that... which is completely different.
What happens in some cases by those that don't do any research, they think that just because a speaker will handle more power, it will be louder, which again, has very little influence on how loud the system will play. However, I don't know any anyone in this forum that isn't doing their homework. These guys are smart and they are researching what is needed. They want a higher sensitivity speaker and the correct resistance (ohms) to match the factory system... and it's been working for us all very well.
