patriot_tech
- Jan 16, 2020
I just got done doing some upgrades to my audio system and figured I'd throw the info out there in case there was interest.
To start, I have a 2020 Limited with H/K. I can't believe they would put a system in that level of truck that sounded that bad. The subwoofer is a piece of garbage - and the tuning of it is no better. The engineers should be ashamed of themselves. A testament to marketing - 19 speakers my rear. The rest of the system is ok at best.
The items I installed are:
Pac AP4-CH41
7 Ea. Faital Pro 3FE22 - 3" wide band driver
4 CDT Audio CL69S - 6x9 Midbass
2 JL 13TW5 subs
JL 1200/1 amp
MTI Sub box - The first stage one box built by them - mine is the actual box on their website.
I am currently using the factory amp to run the mids / highs. The factory sub was unplugged. I took alot of time to reasearch speakers and found the Faital Pro's to be a great match for the factory amp. They are very efficient and 4 ohm. I had to cut one of the tabs off and adjust the screw holes to make them fit right, but not alot of work. They sound great!
I added the subs and amp next. I probably would not have done anything this big, but since I already had the equipment it worked out perfect. Needless to say - I have plenty of bass. Box is VERY well made and worth the money. I somehow managed to get 0 ga into the cab and hidden under carpet to under the back seat.
The last thing I added were the CDT 6x9's. These made a HUGE difference in the sound. Tons of midbass. Music has impact now that it never did before. They dropped right in without issue.
Overall, I am very happy with the stereo now. It sounds REALLY good. By using the factory amp, I have kept all of the functionality of the original system and improved the sound immensely. The efficiency of the Faital's actually make the system louder. At some point I will probably do a DSP and upgrade further, but for now the stereo is perfect.
Pac AP4-CH41
2 JL 13TW5 subs
JL 1200/1 amp
