Accountant
Congrats, and thanks for the pics!
Thanks!
I was going to ask you how it went but see you got it out. Congrats.... Its hard to explain procedures sometimes.... Good for you.
I think I need to fly you to CA lol!
The fascia wiggles side to side but not out and away. I think my clips are engaged in the fender block.
Thanks for your advice. I keep pulling lol.
funny, I thought you had said you had removed that bolt already.... I remember it and got it from the inside holding the fender liner out of the way... also I have a lift so easier to see I guess... too bad it broke but as you said wheel flares will hold it in placeThanks for your help and quick replies! That really meant a lot to know that is should come out without having to unbolt anything else. That tab on the corner of the bracket near the bolt is a doozy though. **** FCA and their overengineering LOL.
How where you able to remove the locking tabs. I’m having a hell of a time with this
Ignore those. They hold the bracket that is attached to the fender. You don't want to mess with those otherwise you will have a large gap between the fender and fascia.I have these two pins though that I can’t get lose. Some kind of push pin
See I don’t have that tap! I have two of those damn pins and they are holding in the Davis because I can feel them move as I try to pull this is driving me nuts! I wouldn’t think they would do anything different with the 2019 rebelThis is the driver side fascia. The red circle is the location that needs to get released first. Once you get this the others come out easily.
See I don’t have that tap! I have two of those **** pins and they are holding in the Davis because I can feel them move as I try to pull this is driving me nuts! I wouldn’t think they would do anything different with the 2019 rebel
I’m going to need some whiskey after that! Got it!Those attach the bracket on the fender. Don't mess with those.
