Here is the electrical paragraph from my contract:
ELECTRICAL: Starter Motor and Solenoid; Generator (Alternator); Engine Control Module -(Single Module Engine Controller) (SMEC); Powertrain Control Module; Distributor; Ignition Module; Ignition Coil; Coil Pack Assembly; Voltage Regulator; Horn and Horn Pad; Transmission Control Module; All Wiring Harnesses; Electronic Fuel Injection System (excluding clogged injectors); Windshield Wiper Motor; Rear Window Wiper Motor; Wiper Control Module; Manually Operated Electrical Switches; Neutral Safety Switch; Temperature Sending Unit/Switch; Oil Level and Oil Pressure Sending Unit/Switch; Body Computer; Body Control Module; Factory Installed Radio, Speakers and Rear Entertainment Systems (Includes CD and DVD Player); Factory Installed Navigation Systems (excludes navigation disc); Audio Amplifier; Height Adjustment Compressor; Gateway Module; Ignition Module, Factory Installed U-Connect System. NOTE: HEADPHONES ARENOTCOVEREDATANYTIME.
