Darksteel165
You do realize there is a 0% chance OP did that?You do realize you can calculate actual miles driving based on error percentage of the tire size when doing hand calculating
Not saying he did, or didn't but you can still get accurate numbers without correcting the speedo for tire size. Just have to factor that into calculationsYou do realize there is a 0% chance OP did that?
Not going to be accurate if trying to calculate mpg imo.He could track miles using google maps or something maybe
What is the diablo sport 87 octane tune?I have gotten better mileage hand calculated than the truck computer and have had worse but usually within .5 to 1mpg. But you bought it used and you should check your speed against a GPS app. It may have never been corrected for the tire size. Is the truck leveled or lifted? This can cause extra drag. I personally have 3.92 gears and am leveled with 34" tire and average 16-17 right now with about 70% highway at 70-80 mph. I will get a little better once it warms up. I also have the Diablo sport 87 octane tune.
Diablo Sport is a company that makes a Tune that can allow you to apply custom tunes or they have some canned tunes when you buy it. One of the tunes is for 87 octane. They also have tunes that require you run at least 91 or 93 octane. The tuner also give some other functions that you can change such as throttle response. This does require an unlocked PCM as well.What is the diablo sport 87 octane tune?
Simular results here on AT 33's + 3.92. Not bad mpg for 4x4 V8 full size imo.I seem to average 13-14mpg all around. I've gotten 20-21 on the highway. Rebel so it has the 3.92's and I have stock size KO2's which are heavy tires. Seems like I am doing OK. I drive very conservatively though. I did just install the Speedform Throttle Controller and leave it on EC.1 most of the time.
I'm not sure WHAT truck you are driving.I'm not sure on how everyone drives their trucks but I'm getting 18 to 19mpg in the city and 25 to 27 mpg on long trips. I have the 3.92 gears and the eco mode that kicks in when needed.
Maybe if he drove 45 the whole way with mds engaged. Definitely won’t get that doing 60+I'm not sure WHAT truck you are driving.
You are not getting 27 mpg on "long trips" with 3.92s, even 3.21s I don't think 27 would be possible on a long trip
