Even though Michigan is a democrat run state, we have some freedoms. Pulling a trailer, you can drive the same 75MPH, as no trailer. I make sure all my trailer tires are speed rated.In komiefornia, any time your pulling a trailer, you're not allowed in the left lane, and of course, 55 mph with a trailer.
I generally keep our speed around 65 mph when pulling our travel trailer. Just to help out the fuel mileage. Fortunately our trailer came with the Goodyear endurance tires that's rated for 85 I believe.Even though Michigan is a democrat run state, we have some freedoms. Pulling a trailer, you can drive the same 75MPH, as no trailer. I make sure all my trailer tires are speed rated.
It depends on what kind of trailer you are talking. I might not drive a travel trailer that fast, but my utility trailer, I have no problem towing over 80, and my boat trailer mid 70s.65 MPH is a good safe speed pulling trailers with autos. (LT and cars) Semi trucks and trailers are safer at higher speeds ON THE OPEN ROAD. Our little trucks (any brands) with 5th wheel or bumper pull trailers are less safe then the Semi's, tire speed rating doesn't mean that an auto with trailer (LT and cars) can safely pull trailers at their speed rating. Have I pulled trailers higher than 65 ? Yes, but that was with quality tires. My favorite tire is the Michelin XPS Rib tire that are well constructed and made for trailers. I crossed interstate 40 (Route 66) from beginning to end at 21K GCW and had to slow down through Arizona and New Mexico, the interstate was so full of pot holes, the rough jerking on my 5th wheel scared the heck out of me, and that was with a high quality 5th wheel hitch.
Semis are not safer at higher speeds. That's why a lot of companies install speed limiters on their trucks. If you load your trailer properly, a 5th wheel or gooseneck trailer is every bit as "safe" as a semi. Bumper pulls can get a bit sketchy, and easier to screw up the tongue weight. Especially on the longer RVs.65 MPH is a good safe speed pulling trailers with autos. (LT and cars) Semi trucks and trailers are safer at higher speeds ON THE OPEN ROAD. Our little trucks (any brands) with 5th wheel or bumper pull trailers are less safe then the Semi's, tire speed rating doesn't mean that an auto with trailer (LT and cars) can safely pull trailers at their speed rating. Have I pulled trailers higher than 65 ? Yes, but that was with quality tires. My favorite tire is the Michelin XPS Rib tire that are well constructed and made for trailers. I crossed interstate 40 (Route 66) from beginning to end at 21K GCW and had to slow down through Arizona and New Mexico, the interstate was so full of pot holes, the rough jerking on my 5th wheel scared the heck out of me, and that was with a high quality 5th wheel hitch.
IMHO, not true!! I've pulled boats, utility trailers, bumper pull camper trailers and 5th wheels. I've also drove many miles in a International LT and a Freightliner Semi pulling 40' containers and 53' trailers, Corporate America cares about MPG, thats the reason for the speed limiter. A Semi is by far better equipped to handle more than 80K GCW, just look at Australia where they have Road Trains pulling 4 or more trailers. So you have a Semi with a 53' trailer on the open road doing the speed limit at 85 MPH, is safer than our little trucks pulling 30K GCW, and some of those have cheap Chinese "will pop" tires that will come apart at 65 MPH, I'm sorry but MHOP is 65 MPH in a LT pulling whatever is legal to pull. I've done 70 MPH towing, but it doesn't mean I was just as safe at 65 MPH. An independent trucker will weigh the MPG vrs time to customer and just the speed accordingly.Semis are not safer at higher speeds. That's why a lot of companies install speed limiters on their trucks. If you load your trailer properly, a 5th wheel or gooseneck trailer is every bit as "safe" as a semi. Bumper pulls can get a bit sketchy, and easier to screw up the tongue weight. Especially on the longer RVs.
If people are pulling 30k gcw trailers with a 1500, no, that's not safe. So if that's what you are basing your opinion on, I would have to agree.IMHO, not true!! I've pulled boats, utility trailers, bumper pull camper trailers and 5th wheels. I've also drove many miles in a International LT and a Freightliner Semi pulling 40' containers and 53' trailers, Corporate America cares about MPG, thats the reason for the speed limiter. A Semi is by far better equipped to handle more than 80K GCW, just look at Australia where they have Road Trains pulling 4 or more trailers. So you have a Semi with a 53' trailer on the open road doing the speed limit at 85 MPH, is safer than our little trucks pulling 30K GCW, and some of those have cheap Chinese "will pop" tires that will come apart at 65 MPH, I'm sorry but MHOP is 65 MPH in a LT pulling whatever is legal to pull. I've done 70 MPH towing, but it doesn't mean I was just as safe at 65 MPH. An independent trucker will weigh the MPG vrs time to customer and just the speed accordingly.
Considering this is a 1500 forum, not sure why we would be taking about HD trucks towing.A light truck is a 1 ton 3500/350 DRW, 3500/350 SRW, 3/4 ton 2500/250. I'd like to see a 1500/150 truck pulling at 30K GCW, that would be something.
According to Louisiana DMW, my 1500 is a 3/4 ton truck.A light truck is a 1 ton 3500/350 DRW, 3500/350 SRW, 3/4 ton 2500/250. I'd like to see a 1500/150 truck pulling at 30K GCW, that would be something.
This post openned the door.I generally keep our speed around 65 mph when pulling our travel trailer. Just to help out the fuel mileage. Fortunately our trailer came with the Goodyear endurance tires that's rated for 85 I believe.
Of course, 1500 is 3/4 of 2000...math says they're right.According to Louisiana DMW, my 1500 is a 3/4 ton truck.
Why you want to put it on me??? Why, why, why?? I was trying to go along with the fuel mileage. Pulling our 5,500lb travel trailer, @ 65 mph we average 11.1 mpg. Anything over and it eats fuel, and since we live in Arizona, anything much slower, in my experience, will get you run over. If I still had my 3500 Cummins and had the right tires on the trailer, I would probably be comfortable doing 70 or 75.This post openned the door.
I get @ 12 MPG towing my 6x12 Cargo trailer with my Harley TriGlide inside. And yes that’s at 65 MPH.
The govt always uses their own formula to figure out how to screw people over, so that makes sense. Stupid that I have to pay like $175 to renew my registration.Of course, 1500 is 3/4 of 2000...math says they're right.
Well my registration here in Arizona is just over $500 for one year. Just over $900 if I pay for two years. My 05' TJR was $150 or so for 5 years.The govt always uses their own formula to figure out how to screw people over, so that makes sense. Stupid that I have to pay like $175 to renew my registration.
