Alter Ego Trip
- Aug 23, 2020
D@mn that box looks sexy as hell
What type/brand of light strip did you use?Slowly putting things back together. Had to completely redo the adapter plates I made to get things to clear door once snapped back together. I moved from 1/2" to 1/4", and it provided just enough room to add CCF between speaker/plate/door, and still clear grille when reassembled (I think lol).
View attachment 186662View attachment 186663
I finished covering the final back of the truck in MLV and cut out the amp rack. I originally was going to mount amps next to each other, between the cab and e torque battery, but it puts the amp behind the center seatbelt and I don't want any chance of having an issue should there be an accident. I don't haul a ton of people, but I do assist with our church youth group, so not taking any chances. This really made for a tight squeeze, but I should just be able to get the amps to fit on top of each other, while barely clearing seat belt.
I disassembled the factory mid housing and cut away the internal surround. She was not made for a 3" plus mid.
I also decided to add some led strips to the doors seeing as they were already apart.
View attachment 186665View attachment 186666
Finished adding CCF to the back of the trim panels.
I now need to turn to glassing a trim panel for the tweeter in the sails. I was going to fiberglass and wrap the whole panel but have since opted to add a panel on top. The design will match the mid speaker shape in the door to tie everything together.
Same as the ones in the doors. Silverholder.What type/brand of light strip did you use?
What RTA program are you using? What type of mic setup do you have? The reason I ask is because I went full active and just picked up TruRTA software for my laptop and a Dayton audio umm-6 mic. I haven’t really dove into it much, but I don’t see how to overlay a target eq curve on my screen while I am making live adjustments, so if I can’t figure it out I may look into different software.
