PorBoy
I had thought strongly about adding the 33 as I only have the 23 now. But since my Ram sits 7 out of 7 days, really did not make sense. Not that anything I’ve done with this truck has ha ha ha.
Yep... you are right. But there has to be a reason my sticker clearly shows it being part of the eTorque option, and why most everyone is getting the 23 gallon tank with eTorque. Perhaps it was the only option at some point. Dunno... it is what it is.Of course I'm talking about the crew cabs. You can't even get the short box on the QC. Again, build out a Big Horn or Laramie yourself with the short box, which can only be in crew cab. You get the 23 gallon tank by default if you select the short bed, whether it's etorque or not.
Sounds like you need to sell your RAM... but then you wouldn't have one, right? lolI had thought strongly about adding the 33 as I only have the 23 now. But since my Ram sits 7 out of 7 days, really did not make sense. Not that anything I’ve done with this truck has ha ha ha.
Interesting thread for sure here (coming from the guy that did the 26 to 33gal swap myself lol).
Don’t know how dealer saying fuel pumps the same. Part number was clearly different. Oh well anyways since it didn’t affect me since 26gal has same pump anyways.
As far as no flash? Yes it works without it. But your distance to empty will always be wrong. Without changing fuel size to 33gal it will show wrong distance to empty (will be based on your previous tank size)
As far as no 3rd strap, uh not sure there. That’s a decent amount of weight hanging there (full tank) from the end of the tank to the middle strap (since third isn’t used). That’s probably 2-2.5ft of a plastic tank with no support I put the strap since I already had a bracket. So was a no brainer. Not calling anyone out here so don’t take it the wrong way.
What's the minimum cost to do this in the driveway?
Things definitely change over time. My window sticker doesn't list a fuel tank size. So I looked at the build sheet to verify my tank size. At the time of purchase I had incorrectly assumed it had a 26 gallon tank. Both of my previous Ram 1500's had 26 gallon tanks, and I had no indication this one was any different. It wasn't until I filled up the first time with about 30 miles in the DTE reading that had me wondering why it only took 19 gallons to fill. I've said it before and I'll say it again...why would they only put a 23 gallon tank on a full sized truck of any configuration?Yep... you are right. But there has to be a reason my sticker clearly shows it being part of the eTorque option, and why most everyone is getting the 23 gallon tank with eTorque. Perhaps it was the only option at some point. Dunno... it is what it is.
Well my 23 gallon is jealous of your 33 one, maybe they can have a play date one day and share ha ha ha..
I can't wait until my parts come in... really looking forward to filling up when I get it. Gonna be soooo nice.
If your build sheet says 26, you have the 26. It was a no cost option. I guess weight means everything. Some e torques have it I guess.Is there anyway to tell by going under your truck and finding a part number to confirm gas tank size? Or maybe measure length of tank? I see different answers all the time and was trying to find a sure way to tell what size tank I have. I checked build sheet and it says 26 gallon tank but must posts say if you have etorque you get 23 gallon tank. I have a 2019 Limited. Thanks.
Let us know what the full range is when its filled up on the 33 gallon. I'm interested in upgrading my 23 as well.I can't wait until my parts come in... really looking forward to filling up when I get it. Gonna be soooo nice.
Will do... still waiting on the tank to get here. My guess is it should be 600+ miles, as I average a little over 20 mpg on most tanks.Let us know what the full range is when its filled up on the 33 gallon. I'm interested in upgrading my 23 as well.
