Front End Low Speed Noise
BJG
Hey Friends,
I have a strange sound that I can primarily hear at low speed. This is when going straight or turning. My truck is a 2020, less than a year old and pretty low miles due to being home a lot obviously.
I recorded this video. Any ideas before I let the dealership start tinkering? (The noise is best heard towards the end of this clip)
Thank You,
Brian
I hear the clunking if that's what you are referring to. Definitely sounds like something is loose, Since you're under warranty let them deal with it. If anything, I would just get underneath and start pushing on things, like the shocks or exhaust.
  • Like
Reactions: BJG
Hey Friends,
Thank You,
Brian
have you made any changes to your truck?
list everything.
  • Like
Reactions: BJG
Check your front sway bar end links particularly where they attach to your a-arm, you’ll have to put a wrench on it to see if the nut is tight, I had mine loosen up on my 2020 Ram 1500 Laramie and it made an annoying clunking sound too.
  • Like
Reactions: BJG
list everything.
Mopar 2" lift, dealer installed.
Mud tires. For sure the knobs might contribute to vibration at low speed.
High clearance front bumper.
Steel running boards / sliders.
Mopar skid plates from rebel.
