boogielander
- Jun 29, 2022
Yeah I'm thinking that's a next year project. I've spent enough this year and $300ish for another 1.5" give or take.... I'll waityou should be ok with the non HD coils.
i think they'll give a tad bit under 2.5" (advertised 2.5") becuase our bed are heavier than the JT bed
and i don't think it matters if it was DT or JT, 2.5" is 2.5" lol
yeah just let it settle a bit. heck maybe you'll do an Arctic run next year and then come back realizing you need all 4 springs lolYeah I'm thinking that's a next year project. I've spent enough this year and $300ish for another 1.5" give or take.... I'll wait![]()
this is when i say "i told ya so" LOLLLI installed the Thuren Rear Trackbar last week and the Thuren Rear U/L CAs today...fairly easy job, I ran the truck up on ramps for more room to work.
Using a 1" Torque wrench was still nearly impossible to get leverage with one hand and wrench on the other, so after torquing first nut to 215ft/lbs as Thuren recommends for all U/L CA bolts/nuts, I resorting to using my Ryobi High Torque Impact to remove..and install all the bolts/nuts. My UCs have solid steel ball joints, so you can't really over torque them.
Anyways..HOLY CRAP!!!
The difference in how solid, and fluid, and smooth, and planted the rearend is now was immediately noticable before I even got out of the driveway!!
The rearend feels smoother than the front end now..crazy!!
Strangely, the posi wants to spin the inside tire now in tight accelerating corners..old truck did that as it was lighter, but not this one until now!! Must be putting power down better since less rearend movements(??).
Bumps are so smooth..and NO more stretch, slingshot, double bounce anymore..just smooth, controlled movements..the tires and shocks are actually doing their job without annoying movements!!
I can absolutely feel how loose and stretchy the front U/L CAs are now. Fortunately, I'll be swapping in the Thuren Front UCAs in a few weeks when I swap in the Fox 2.5 PE DSCs to relieve some of that.
Honestly, I feel like the Foxs aren't really needed now, but I've got them so might as well try for the next level of comfort, but I'm actually not unhappy with my Eibach Pro-Trucks anymore.
(One deviation I made..I wanted ALL my Zerks facing downwards, so I removed the Thuren stickers, flipped the Lower CAs upside down, added new stickers, and installed then that way..there is no reason I can work out that this would cause a problem. I removed the L side cable bracket to clearance the gas tank, but that probably wasn't necessary).
THUREN is amazing
View attachment 204687View attachment 204688View attachment 204689View attachment 204690
Some of our Wisco roads can feel like off roading, but you more than most would probably be amazed at how your boogielanding could be faster and next level.this is when i say "i told ya so" LOLLL
hmm maybe i'll do it then just because i need to find something to do
I Feel this....(man, I really am getting old..in my younger days, I couldn't wait a day with new parts)
currently i have absolute zero complain about the rear suspension. i think it's because with all the weight and stuff they actually help with keep the rear in check.Some of our Wisco roads can feel like off roading, but you more than most would probably be amazed at how your boogielanding could be faster and next level.
I used my first JJ-style CAs from Global West (delrin bushed) on a couple Camaros over 15 years ago..and have been a huge fan of them ever since..they can transform a solid axle car into feeling almost independent.
Thuren says they worked with Creative Steel to get the Poly compound just right for their JJ bushings for the right rigidity, movement, wear, and NVH..and recommend and sell Creative Steel's Polyurethane Bushing Grease to go with their CAs. They like it better than RednTacky, so I bought and used it.
Concrete and road cracks mostly disappear now, and bumps are just bumps..subdued, smooth, and no secondary rebound or movements.
The rear CAs are $880 and the trackbar is $240..and to me, are worth every cent!
I'm actually considering swapping in the Thuren Front UCAs before doing the Fox PEs, just to document how much difference the full Thuren suspension "package" makes on it's own. Swapping just the UCAs wouldn't be that difficult, I just have to find the time. The next two weeks of Wisco summer are going to be very busy, so Foxs won't be for a few weeks yet (man, I really am getting old..in my younger days, I couldn't wait a day with new parts)
I should mention, I'm running 5psi in my Airlift bags, and have settled on 39psi F & 35psi R in my 285/60 Ascents..especially now, this seems to be best balance, comfort, and handling for me.
Super freakin happy with the Thurens!
Nope, those are Thuren's Black Shock Boots for 2.5" shock bodies.The rears come with boots now? Interesting.
I'm curious if you know which Eibach rear coil you have?The Eibach rear coils say 1"-1.5" which would be .5" more than the stock Rebel coils. I didn't think it would actually be 1.5 but it was. And I didn't think I could notice .5 inches by eye. But I can. And... it turns out it doesn't make any difference. They are much more progressive than the stock coils(go figure). Very nice for high speed with no load. Not so great when you have a load. So, I added airbags. Talk about a rabbit hole. So, do your research and decide if it is really something you want to do. Make sure the one's you want are the one's you need.
Great job.Ok, so I got the Front and Rear Fox PEs installed along with the Thuren UCAs today.
Thankfully, I decided to install them "As Sent" from Fox, because I got my wish I guess (2.5"F)..I had planned on doing a +1"F/+1"R over what my Eibachs were (+1.5"F/+0"R) originally when I ordered the Fox PEs..I even ordered the Core4x4 rear endlinks for +1" (12.25").
Fox had told me that I probably wouldn't get the "As Advertised" +3.0" Front lift because my Laramie is heavily loaded..they actually said probably 2.5", but maybe as much as 2.75"..turns out I got +1"L(2.5") and +1.125"R(2.625").
Problem is..since my Eibachs on Clip#2 (0.6") with ORP springs (1") gave me 1.6", I figured I get the full 3.0" "As Advertised" not the 2.5" that I actually got..so when I did the rear suspension before the front suspension, I had to pick to either use my 1" coil spacers, 1.5" coil spacers, or go completely new with the +1" Eibach rear coil springs that I also have.
I decided I want to keep my rear ride consistent with what I knew was comfortable, so bet on the 1.5" rear coil spacers..and got a real +1.5" lift in the rear.
It rides and handles fine, but I now have 0.5" rake and I hate the look, so this weekend I'll redo the rear suspension to lower it a half inch.
I'm gonna swap out the 1.5" spacers for the 1" spacers and I should be back to dead level again.
With my previous +1.625" leveled lift, my camber was close to Zero and steering and handling were awesome, but at +2.5" I have a definite Positive camber, so even though the ride and handling aren't bad, it will certainly be better with an alignment.
Because of the +camber, I'll need that alignment pretty quickly..if I had time, I'd maybe think about also swapping in the +1" Eibachs rear coils in place of the +1" rear coil spacers.
Once the alignment is done, I should be able to run the spacers for a while to see what I think, and then swap in the Eibachs since the rear lift would be +1" with either so the alignment shouldn't be affected.
@boogielander ..I know I said I love doing suspension work..I think I lied, I getting too old for this sh*t! And, I get frustrated when I do all kinds of planning..and then I still have to redo my work because of unforseen issues. But modding begets modding..there's no playbook, just trial & error.
I can say that even in this first "trial" setup, the Fox PEs with Thuren UCAs are much smoother over the large cracks/holes/irregularities, which is what I'm doing this swap for! On smooth roads, there really isn't any noticable difference over the F&R Eibach Pro-Trucks & Front ORPs that I had..they were really good..just not on bad roads, especially since the bigger, wider, heavier new wheel/tire setup.
I did limited driving today with all four set to 3L/5H. I readjusted them to 2L/4H for the next limited drive. I won't mess with the valving much until I get the alignment done..then I'll be able to have a better baseline.
Also, I'm currently running 39psi F & 35psi R and I'll play with that some more also. My gut tells me 39F/37R might work better with the Foxs(?), we'll see.
View attachment 206893View attachment 206894
very nicely done!Ok, so I got the Front and Rear Fox PEs installed along with the Thuren UCAs today.
Thanks much!Great job.
Yep..ALL on the ground!!very nicely done!
i told ya you wouldn't be disappointed! (also told ya it's not fun to do it on the ground - assuming you did it on the ground - but if you can do it on a lift then that makes it a lot more enjoyable process)
i think 2psi in the back can help a bit but not much. I ran 40 PSI all around before after new spring rates (600lb front, Clayton triple rate HD rear) and it was a bit too much, so went down to 35 psi and it helped. then currently i'm actually at 32-33 PSI (last I aired up was at high elevation and when i came down it dropped). Ride quality improved a bit now compared to at 35 PSI all around, but not a whole lot.
*note: i run equal pressure all around because I use a 4 way hose system to air down and up for simplicity and efficiency. if i don't air up and down a lot then i'd play with different front and rear pressure. to me it makes no sense to do dedicated pressure front and rear when im airing down and up a lot (though... i should probably do that because im not airing down as often now. sometimes when i go camping and go easy trails I just drive through instead of airing down lol just being lazy)
